New 2x2mm addressable WS2812 leds, WS2812-2020
Tubular
These new Worldsemi leds are bit more hobby friendly compared with the 3535, 2427, other 2020 types that have intricate pads underneath. These ones have castellations, so they're a whole lot easier to hand solder - not that different to soldering SOIC ics
So far I've found they like a buffer to drive with a solid 5v signal, and also the red/green bytes seem swapped. Further investigation required.
Their pdf link is empty
All that makes them a great match for compact 3v3 Prop projects.
hmm, seems that labeling is vague, this link (Nov 2018) mention an upgrade IC
http://www.world-semi.com/DownLoadFile/141
"we do not enable a new part number,
only add a suffix version number to distinguish. "
- and the data sheet WS2812C-2020 Sept 2018 is not yet updated to show what that suffix version number might be.
Looks to have a 3v3 Logic threshold improvement (Vih < 2.8V), and better driver current, but still suggests > 3.5V for LED power. just due to LED voltage drops
They're still a 5v device, they just work better than ws2812b when running from 3v3. Plus the logic threshold you mention means you don't need to run your P1's at 3v6
