HELP!! SPIN coding problem with LEDs lighting on down count.
I feel embarrassed to say this, but for the life of me I can't figure out what it is thats screwed up in this code. All its supposed to do is make a series of 8 LED lights turn on one at a time and go back and forth.
Var
Byte Pin ' I/O pin.
PUB Toggle {Made to toggle 8 LEDs on and off in sequence from low to high and then high to low}
Pin := 16 ' Set value to first pin
dira[Pin]~~
Repeat
Repeat until !outa[Pin]++ == 23 ' Go up one pin at a time to pin 23
waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles
Repeat until !outa[Pin]-- == 16 ' Go down one pin at a time to pin 16
Var
Byte Pin ' I/O pin.
dira[Pin]~~
Repeat
You are doing it slightly wrong, here a better version
Enjoy!
Just one question - if I alter the code slightly to shut off the led once they are turned on but putting !outa[Pin] after waitcnt, why doesn't it work going from 23 to 16? So it would read as
!outa[pin]
If I do !dira[Pin] it will light up on the way back to 16 but not shut off the others.
For my normal work I have a library called jm_io.spin which handles essential pin IO functions.
The LEDs will light up for 1/4 second and then shut off for 1/4 second. The LEDs move from pin 16 to 17 to 18 etc. However, on the way down from 23 the LEDs will not light up - or not light properly. There should be one light on at a time and the light should move back and forth across string of lights.
For ease of coding I am using the Propeller Demo Board Rev G since it already has LEDs on it.
This code works halfway, but it is bulky and crude. At this point I will take bulky and crude if it will run like its supposed to.
'not light properly' is too vague to be useful.
Do the leds (all/some/partial?) fail on down-slope only, and work ok on every up slope time window ?
The LEDs are one to each pin on pins 16 - 23. Pin 16 goes high turning on that LED and after 1/4 second the pin goes low shutting off the LED. This repeats up to pin 23.
BUT
When the pins go from 23 - 16 it doesn't work and only a very faint LED light is visible as the pins count down from 23 to 16.
"doesn't work and only a very faint LED light is visible" is still vague. Does that mean the timing is as-expected, but each single on LEDs is faint, or all leds light, but faint, or something else ?
The small details matter a lot, and help you figure out possible causes.
In other words, it works with timing as it should, but the LEDs won't fully light up when subtracting a pin. I will try to post pictures since the video clip can't post.
I don't mean to be blunt, but you're writing code in a bit of an obtuse manner. In my opinion, it's always best to write code that is obvious.
It seems that you now want to create a Larson Scanner (Cylons, Kit car) -- I didn't understand that from your initial post. As I live and work in Hollywood, I've written lots of Larson scanner code. Here's one way that I think is easy to follow.
There are many roads that lead to Rome, and many ways to solve the same programming problem. Here's one that's close to your style -- if a bit more obvious:
Here is what I got to work.
Also, I suggest you avoid arcane operators when possible. This: ...uses an arcane operator and requires a comment. This version, however... ...would be understood by a fellow embedded programmer and actually runs more than half a microsecond faster. Yes, microseconds count. Not in this program, but if you do enough coding you will come to a point where you are fighting for them. I wrote a very complex (about 6000 total lines) laser-tag control program and I was scrambling for every bit of time savings I could muster. The great thing about the Propeller is that you can use standard code to do timing tests -- here's what I used: In my program, term is an instance of FullDuplexSerial (my variation). The -544 in the final calculation accounts for the Spin overhead. If you remove code from between the updates of elapsed you should get 0.
Finally, if I had been commissioned by on of the special effects clients to write this code, I would have given them this (archive is attached). This follows the rule by one of my colleagues: If you find yourself writing the same block of code more than once, it's time for a function/method. I frequently remind the new programmers in work to break their code into small, atomic functions/methods so that the code the write has more clarity and the ability to be re-used.
You'll get there. I just takes time and practice.
