Back playing with the Prop again
in Propeller 1
It's been some time since I played with the propeller, but I've recently pulled my chips and components out again and gotten myself re-hooked on this awesome little chip! I think about 2009 was the last time I did anything with the prop, I was experimenting with interfacing the prop with my trucks engine management system and managed to blow one of the fuel injection driver mosfets, which ended up with me putting my stuff into storage and moving on to other past times.
I'm just running a DIP40 chip from a breadboard at the moment, but have pulled out some of my old board designs and made some revisions which I've sent off to JLCPCB to be made into PCB's. Can't wait to get soldering again!
Also a 1uF-10uF across the main power input on your breadboard. Tantalum is better but electrolytic will work. I presume your power supply is already regulated nicely.
Thanks for that, I'll have a dig through my box and add the caps. I'll also add the power and gnd to the other sides of the prop.
Besides the prop-plug and the DC-DC converter, there is an SH-H3 bluetooth module (designed for an Arduino, but I've gotten it to work nicely with the prop).
I managed to blow the mosfet on my ECU by not using enough resistance while trying to read injector pulse width with the prop.
if practical.
