Access to CNT register — Parallax Forums
I apparently have suffered drain bamage. I cannot find how to read the cnt register. If I say
mov  stime, cnt      'get pulse start time
it says "error symbol cnt is not constant".
Please help.
  • For prop2, use GETCT instruction. WAITCNT is replaced by WAITCTx and ADDCTx for x=1,2,3
            getct   stime
  • RaymanRayman Posts: 16,006
    Hmm... I wonder how the new 64-bit CT register will handle rollover for wait and add...
    Guess it works out to be the same as with 32 bit CT register...
  • Thank you, @Mark_T .
    Rayman wrote: »
    Same as it does now. The only change is the cnt is extended to 64 bits and you can read the high 32bits. Otherwise those top 32 bits are hidden/unused.
