HELP!! SPIN coding problem with LEDs lighting on down count.
I feel embarrassed to say this, but for the life of me I can't figure out what it is thats screwed up in this code. All its supposed to do is make a series of 8 LED lights turn on one at a time and go back and forth.
Var
Byte Pin ' I/O pin.
PUB Toggle {Made to toggle 8 LEDs on and off in sequence from low to high and then high to low}
Pin := 16 ' Set value to first pin
dira[Pin]~~
Repeat
Repeat until !outa[Pin]++ == 23 ' Go up one pin at a time to pin 23
waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles
Repeat until !outa[Pin]-- == 16 ' Go down one pin at a time to pin 16
Var
Byte Pin ' I/O pin.
dira[Pin]~~
Repeat
You are doing it slightly wrong, here a better version
Var Byte Pin ' I/O pin. PUB Toggle {Made to toggle 8 LEDs on and off in sequence from low to high and then high to low} Pin := 16 ' Set value to first pin Repeat Repeat dira[pin] := 1 outa[pin] := 1 waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles until Pin++ == 23 ' Go up one pin at a time to pin 23 Repeat dira[pin] := 0 outa[pin] := 0 waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles until Pin-- == 16 ' Go down one pin at a time to pin 16Enjoy!
Just one question - if I alter the code slightly to shut off the led once they are turned on but putting !outa[Pin] after waitcnt, why doesn't it work going from 23 to 16? So it would read as
!outa[pin]
If I do !dira[Pin] it will light up on the way back to 16 but not shut off the others.
pub main | pin repeat { forever } repeat pin from 16 to 23 high(pin) waitcnt(cnt + (clkfreq >> 2)) repeat pin from 16 to 23 low(pin) waitcnt(cnt + (clkfreq >> 2)) pub high(pin) outa[pin] := 1 dira[pin] := 1 pub low(pin) outa[pin] := 0 dira[pin] := 1For my normal work I have a library called jm_io.spin which handles essential pin IO functions.
The LEDs will light up for 1/4 second and then shut off for 1/4 second. The LEDs move from pin 16 to 17 to 18 etc. However, on the way down from 23 the LEDs will not light up - or not light properly. There should be one light on at a time and the light should move back and forth across string of lights.
For ease of coding I am using the Propeller Demo Board Rev G since it already has LEDs on it.
This code works halfway, but it is bulky and crude. At this point I will take bulky and crude if it will run like its supposed to.
Var Byte Pin {I/O pin to toggle on/off. Good from 0 - 255} PUB Toggle Pin := 16 {Set value of pin to starting point} Repeat repeat while pin < 24 ' Repeat the following dira[Pin]~~ ' Set I/O pin to output direction !outa[Pin] ' Toggle I/O Pin waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles dira[pin]~ waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles Pin += 1 ' Go to next pin. Short form of Pin := Pin + 1 repeat until pin < 16 dira[Pin]~~ ' Set I/O pin to output direction !outa[Pin] ' Toggle I/O Pin waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles dira[pin]~ waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles Pin -= 1 ' Go to next pin. Short form of Pin := Pin - 1'not light properly' is too vague to be useful.
Do the leds (all/some/partial?) fail on down-slope only, and work ok on every up slope time window ?
The LEDs are one to each pin on pins 16 - 23. Pin 16 goes high turning on that LED and after 1/4 second the pin goes low shutting off the LED. This repeats up to pin 23.
BUT
When the pins go from 23 - 16 it doesn't work and only a very faint LED light is visible as the pins count down from 23 to 16.
"doesn't work and only a very faint LED light is visible" is still vague. Does that mean the timing is as-expected, but each single on LEDs is faint, or all leds light, but faint, or something else ?
The small details matter a lot, and help you figure out possible causes.
repeat until pin < 16 dira[Pin]~~ ' Set I/O pin to output direction waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles - need to delay before turning off the led !outa[Pin] ' Toggle I/O Pin ' waitcnt(clkfreq/4 + cnt) ' This line needs to be before the !outa[pin] dira[pin]~ waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles Pin -= 1 ' Go to next pin. Short form of Pin :=In other words, it works with timing as it should, but the LEDs won't fully light up when subtracting a pin. I will try to post pictures since the video clip can't post.
I don't mean to be blunt, but you're writing code in a bit of an obtuse manner. In my opinion, it's always best to write code that is obvious.
It seems that you now want to create a Larson Scanner (Cylons, Kit car) -- I didn't understand that from your initial post. As I live and work in Hollywood, I've written lots of Larson scanner code. Here's one way that I think is easy to follow.
pub main | pin repeat { forever } repeat pin from 16 to 22 high(pin) waitcnt(cnt + (clkfreq >> 3)) ' delay 1/8 second low(pin) repeat pin from 23 to 17 high(pin) waitcnt(cnt + (clkfreq >> 3)) low(pin) pub high(pin) outa[pin] := 1 dira[pin] := 1 pub low(pin) outa[pin] := 0 dira[pin] := 1There are many roads that lead to Rome, and many ways to solve the same programming problem. Here's one that's close to your style -- if a bit more obvious:
pub main | pin outa[23..16] := %00000000 ' set LEDs to outputs dira[23..16] := %11111111 pin := 16 repeat { forever } repeat outa[pin] := 1 waitcnt(cnt + (clkfreq >> 3)) ' delay 1/8 second outa[pin] := 0 while (++pin < 23) repeat outa[pin] := 1 waitcnt(cnt + (clkfreq >> 3)) outa[pin] := 0 while (--pin > 16)Here is what I got to work.
Var Byte Pin {I/O pin to toggle on/off. Good from 0 - 255} Byte Rate {Number value that controls the speed of the LED Light} PUB LED_Light Pin := 16 {Set value of pin to starting point} ' Final Value to start zero Rate := 11 ' TEST VALUE ONLY. REAL VALUE WILL BE SENT FROM OTHER SOURCES. Repeat Repeat while Pin =< 23 ' Repeat the following dira[Pin]~~ ' Set I/O pin to output direction !outa[Pin] ' Toggle I/O Pin if Pin <> 16 waitcnt(clkfreq/Rate + cnt) ' Wait for delay cycles dira[Pin]~ ' Set I/O pin to input direction if Pin <> 23 waitcnt(clkfreq/Rate + cnt)' Wait for delay cycles Pin += 1 ' Go to next pin. Short form of Pin := Pin + 1 Repeat while Pin => 16 dira[Pin]~~ ' Set I/O pin to output direction if Pin <> 23 waitcnt(clkfreq/Rate + cnt) ' Wait for delay cycles - need to delay before turning off the led !outa[Pin] ' Toggle I/O Pin dira[Pin]~ ' Set I/O pin to input direction if Pin <> 16 waitcnt(clkfreq/Rate + cnt)' Wait for delay cycles Pin -= 1 ' Go to next pin. Short form of Pin := Pin - 1Also, I suggest you avoid arcane operators when possible. This: ...uses an arcane operator and requires a comment. This version, however... ...would be understood by a fellow embedded programmer and actually runs more than half a microsecond faster. Yes, microseconds count. Not in this program, but if you do enough coding you will come to a point where you are fighting for them. I wrote a very complex (about 6000 total lines) laser-tag control program and I was scrambling for every bit of time savings I could muster. The great thing about the Propeller is that you can use standard code to do timing tests -- here's what I used: In my program, term is an instance of FullDuplexSerial (my variation). The -544 in the final calculation accounts for the Spin overhead. If you remove code from between the updates of elapsed you should get 0.
Finally, if I had been commissioned by on of the special effects clients to write this code, I would have given them this (archive is attached).
pub main setup ' Larson scanner ' -- avoids "sticking" on end boundaries repeat { forever } zip(LSB, MSB-1, ON_MS) zip(MSB, LSB+1, ON_MS) pub zip(first, last, ms) | idx '' Sequence outputs from first to last '' -- output delay in milliseconds repeat idx from first to last io.high(idx) time.pause(ms) io.low(idx)This follows the rule by one of my colleagues: If you find yourself writing the same block of code more than once, it's time for a function/method. I frequently remind the new programmers in work to break their code into small, atomic functions/methods so that the code the write has more clarity and the ability to be re-used.You'll get there. I just takes time and practice.
