Measuring cable length using optical encoder
in BASIC Stamp
Hi,
I am building a cable robot and want to integrate a closed loop system. I wish to measure the change in thin cable lengths at certain point but I can not find anything suitable to do this. I basically want a linear encoder to measure the distance that the cable moves, but every encoder that I have found only works with codestrips.
Any help would be appreciated,
Please read the Forum Rules here:
http://forums.parallax.com/discussion/134682/forum-rules-and-guidelines#latest
BTW, I'm puzzled that the device can't interact physically with the cable. What would be wrong with adding encoders to the winches that control the cable or to the pulleys the cables ride over?
A optical mouse sensor would be perfect for the job, however the only information that that I can find online, is too tear apart an old PS/2 mouse and use its parts, do you know of any other way this can be done?
-Eoghan
https://www.parallax.com/sites/default/files/downloads/28560-Mouse-Sensor-Kit-Product-Documentation.pdf
Your best bet is probably to repurpose either an optical (serial or PS2) mouse.
Thanks very much for your help Phil, Repurposing a PS2 mouse seems to be the way to go.
Also perplexed, please do elaborate. More info might result in a better suggestion.
I am not sure the mouse idea would be very accurate. The image is going to have randomly placed patterns and areas that may be smooth enough that no movement can be detected. Think of what happens when you place the mouse on a smooth single colored surface.
