Double Precision Binary-to-BCD: ALTS/D thoughts
tomcrawford
in Propeller 2
I adapted a DP Bin2BCD routine for Prop2. The routine repeatedly subtracts double precision powers of 10, beginning with 10E19.
The change from the Prop1 method is that it uses Register Indirection. Here it is.
The prop1 method used self-modifying code to directly point into the table of powers of ten; this uses register indirection.
The nice news is no more self-modifying code; the not-so-nice news is that the inside loop goes from three instructions to five (beginning at B2BL2).
You pays your money, you takes your choice.
I was gonna get all philosophical here about whether avoiding self-modifying code is A Good Thing, but won't.
Bin2BCD mov x, #0 'clear index regs (goes by 1)
mov y, #0 'goes by 2
mov temp, #20 'will do 20 digits
B2BL1 mov count, #0 'used to count subtracts
B2BL2 alts y, #E19+1 'index into DP 10**X table
sub BinLo, 0 wc 'subtract lo order
alts y, #E19
subx BinHi, 0 wc 'subtract hi order
if_NC djnz count, #B2BL2 'still positive, adjust count
altd x, #tens
abs 0, count 'save result
alts y, #E19+1
add BinLo, 0 wc 'restoring add
alts y, #E19
addx BinHi, 0
add x, #1 'adjust indexes
add y, #2
djnz temp, #B2BL1 'do next power of temp
Bin2BCD_ret ret 'all done
Basically alts, altd, alti are self-modifying code like we used on the P1, just without the hassle of counting instructions in between modifying and using.
I am slowly diving into PASM2 and like it a lot, already...
Code is quite compact too.
