Parallax WX ESP8266 disable remote code load
iseries
                                  in Accessories
                    I have the ESP8266 board and have used it to load some code on a Prop board.
Now I want to hide it from the simpleIDE so that I don't accidently load some other code on it.
Is there a way through the web page for the unit to disable the UDP code so that it doesn't respond?
If that sounds like a good solution, I could get the firmware file for you next week, along with the code snippet and wiring info.
Since the unit is now in production run mode I don't want it to show up so I don't have to deal with it.
There should be an option on the web page to turn it off so it works like an ESP8266 device.
At this point I am thinking about replacing it with an ESP8266 unit.
I mean, could you power down the WiFi module whilst you don't need to be programming the Propeller over wifi ?
If that is the case, just hold the wifi module reset pin low to keep it off. That's the pin next to Gnd on the SIP header.
So no, can't turn the unit off or unplug it.
I did see in the code that there is a function called "initDiscovery". I need to add some code that sets a variable that it checks before it tries to start this service. That should fix my problem.
On the setting screen I added a new parameter that allows me to hide the unit.
I also went ahead and built the product using almost the latest SDK 2.2.1
So far works great.
