MAX 31850 on one wire bus with DS18B20
in Propeller 1
Can these work on the same bus? I can get the DS18b20 to read but not the thermocouple amp.
Aaron
Aaron
In the adafruit site is says it is not a drop in.
I'm hoping someone has some code that works with this
Aaron
Is there a way to modify the output of the one or both to work together?
Aaron
The MAX 31850 is a onewire device not SPI.
Aaron
I don't know which 1W driver you're using, but I've attached mine which has been used in several commercial apps.
Since I can get the 31850 to work by itself, I'm now trying to use a separate cog for it. Just need to sort the variables so there is no cross talk and will probably use a different 1W driver for it than the 18B20s. I need to study up on how to use cogs and types of memory. It's been a while since I last did these things.
Aaron
