Dumb level-shifting question
in Propeller 1
I want to connect the output of a 5V chip to a Propeller input pin. I found a step-down level shifter circuit here which seems nice and simple, but being super lazy I'm wondering if I can simplify it even further: just connect output to input with a resistor. Am I a genius or an idiot? LMK.
The input-signal high level (VIH) can exceed the VCC supply voltage when these devices are used for logic-level conversions
Also don't forget that there are resistor arrays which just about every Parallax board or module uses.
Resistor arrays come in 2 versions: individual or common pin.
A group of LEDs would use a common pin array since they will all either be connected to power or ground.
That was not a 'dumb' question by the way.
