MAX 31850 on one wire bus with DS18B20 — Parallax Forums
Can these work on the same bus? I can get the DS18b20 to read but not the thermocouple amp.
Aaron
  • I'd have though it would be fine, but are you using a library that expects its device code?
  • I played with this several years ago and somehow got a 64 bit code for it but now I can't repeat that and I get nothing when I put in the code.
    In the adafruit site is says it is not a drop in.
    I'm hoping someone has some code that works with this
  • OK I rewired and checked all connections. Found nothing wrong but now it works. Sorry for the useless post.
    Aaron
  • So now when I read both the 31850 and a DS18B20, because they are not at the same resolution, the 31850 reads bogus. It does not, in the data sheet, look like the resolution of the 31850 can be changed from 14 bits. I have been running the 18B20 at 9 bits resolution and 12 is max for it.
    Is there a way to modify the output of the one or both to work together?
    Aaron
  • I made a separate program to read thermocouple alon and it works fine but when added to the program with several DS18B20s, it reads bogus. The 18b20s read fine. here is my code
    CON
      _clkmode = xtal1 + pll16x      '80 MHz system clock        needed for TV
      _xinfreq = 5_000_000
                 3.3v      3.0 - 5.5v
               4k7  │   │ │               'for long wires use 1k pull up
      1W pin ─────┻──┼┻────── more sensors
    OBJ
      ow  : "spinonewire"
      tv  : "tv_text"
    VAR
      long addrs0[2],addrs1[2],addrs2[2],addrs3[2]  '64 bit sensor addresses
      long A_temp,B_temp,C_temp,D_temp     'designation of various sensors
      long  firstSens,secondSens,thirdSens,thermocouple,degF
    PUB init        ''start objects and define 1wire addresses
      waitcnt(clkfreq*2+cnt)  '2 seconds for TV to come on
      tv.start(0)
      ow.start(10)
         'define device addresses of temp sensors
             'use spin_onewire_test to determine addresses of devices
      addrs0[0]:=$3e676928        'least significant long of 64 bit address         shop
      addrs0[1]:=$87000006         'most significant long of 64 bit address
      A_temp := @addrs0          ' the memory location of complete 64 bit address value
          'other sensors
      addrs1[0] :=$3F560228
      addrs1[1] :=$7A000006                                                       ' coop
      B_temp := @addrs1
      addrs2[0] :=$70056F28
      addrs2[1] :=$7F011431                                                       'boiler
      C_temp := @addrs2
      addrs3[0] :=$182CAA3B
      addrs3[1] :=$CC000000                                                       'chimney
      D_temp := @addrs3             'thermocouple,
      'setconfig(12,0,0)  'leave commented out unless you want to change the
                                       ' resolution of all the devices
      main
    PUB  main  ''loop
      repeat
        firstSens:=readTemperature(A_temp)
        waitcnt(clkfreq/10+cnt)
        secondSens:=readTemperature(B_temp)
        thirdSens:=readTemperature(C_temp)
        thermocouple:=readT_couple(D_temp)  'read device
        tv.home
        tv.str(string("Shop temp = "))  'may read 7403°F or very close to 32 if no sensor
        showf(firstSens,0)
        tv.str(string(13,13,"Coop temp = "))
        showf(secondSens,0)
        tv.str(string(13,13,"Boiler Temp  = "))
        showf(thirdSens,0)
        tv.str(string(13,13,"Chimney Temp  = "))
        PrintF(thermocouple)
    PUB readTemperature(addr) | temp,dsOut
      '' Read the temperature from a DSxxxxx sensor, and return it.
      ' Blocks while the conversion is taking place.
      ow.reset
      ow.writeByte(ow#MATCH_ROM)
      ow.writeAddress(addr)    '64 bit address of device being addressed
      ow.writeByte(ow#CONVERT_T)
      ' Wait for the conversion
      repeat
        waitcnt(clkfreq/100 + cnt)
        if ow.readBits(1)
          'we Have a reading! Read it from the scratchpad.
          ow.reset
          ow.writeByte(ow#READ_SCRATCHPAD)
          dsOut := ow.readBits(16)
          'degF := (temp << 4)*9/5+32
          temp := ~~dsOut * 625           ' extend sign, 0.0001° units
          return  temp
    pub showf(temp,places) | tp,Modulus  'places = number of decimal places to show
    '' Print temperature in degrees Fahrenheight w/(places) number of decimals
    ' -- temp is passed in C
      case places                   'this added by AG
        0  : Modulus:=0     'integer only
        1  : Modulus:=10    '1 decimal
        2  : Modulus:=100    '2
        3  : Modulus:=1000    '3
        4  : Modulus:=10_000   '4
      if (temp > 0)
        temp := temp * 9 / 5 + 32_0000
      else
        temp := 32_0000 - (||temp * 9 / 5)
      if (temp < 0)     'if negative
        tv.out("-")
        ||temp
        'print degrees w/ selectable number of decimal places
      if Modulus==0
        tv.dec(temp / 10_000)     ' print whole portion truncated
      else
        tv.out(".")
        tv.dec(temp // Modulus)  ' print fractional portion
      tv.out(176)
      tv.str(string("F    "))
    PRI readT_couple(_addr) | temp,dsOut, degC
      ow.reset
      ow.writeAddress(_addr)    '64 bit address of device being addressed
      repeat
        if ow.readBits(1)
          ' Have a reading! Read it from the scratchpad.
          ow.reset
          temp := ~~dsOut * 504           'calibrate temp (lower value = lower readout) tested @ 175 F
          return  degF
    PUB PrintF(FAR)
      tv.dec(FAR / 10_0000)     ' print whole portion truncated
      tv.out(176)
    pub setconfig(resolution, th, tl) | cfg
    '' Sets temperature resolution, 9 to 12 bits
    '' th and tl are passed in whole degrees C
    '' comment out in PUB init unless you want to change the resolution of all the devices
      case resolution  {Resolution bits...}
            9: cfg := %0_00_11111
           10: cfg := %0_01_11111
           11: cfg := %0_10_11111
        other: cfg := %0_11_11111
      ow.reset
      ow.writebyte(ow#SKIP_ROM)
      {Write to scratchpad...}
      ow.writebyte($4E) {Three bytes follow this command...}
      ow.writebyte(th)
      ow.writebyte(tl)
      ow.writebyte(cfg)
      ow.reset
      {Write configuration into EEPROM...}
      ow.writebyte(ow#COPY_SCRATCHPAD)
      repeat until ow.readbits(1)   {let copy finish}
      ow.reset
    DAT
    and a screen shot of TV. this is with thermocouple on table
    4288 x 2416 - 3M
  • FWIW, I don't know if I'd share pins between 1W and SPI devices. Remember, 1W devices are open-drain and any twiddling on the pin they share with others could cause it to connect that pin to ground (as if it's outputting a bit) and fouling the SPI transaction.
  • Jon
    The MAX 31850 is a onewire device not SPI.
    Aaron
  • Forgive me -- there is a SPI version with a part number that is close (MAX31855). I used it some time ago in an HVAC controller.
    I don't know which 1W driver you're using, but I've attached mine which has been used in several commercial apps.
  • Thanks Jon
    Since I can get the 31850 to work by itself, I'm now trying to use a separate cog for it. Just need to sort the variables so there is no cross talk and will probably use a different 1W driver for it than the 18B20s. I need to study up on how to use cogs and types of memory. It's been a while since I last did these things.
    Aaron
