XBee Cellular
MikeDYur
                                  in Accessories
                    Couldn't find any information on the forums, and I don't know why it hasn't been brought up yet.
But this module may be the answer to an alarm system problem I have, no land line = no connectivity.
Digi XBee Cellular embedded modem
https://www.digi.com/products/xbee-rf-solutions/embedded-rf-modules-modems/digi-xbee-cellular
https://www.digi.com/news/press-releases/digi-reshapes-embedded-cellular-market
EDIT: This is on the Verizon 4G LTE network.
I don't have time to do this, but if there's a capable forum member who'd like to get this up and running for us I'd send them my development kit. Post your interest here and don't use PMs to reach me - I don't have time to read them anymore (and I'm very sorry for that - it's just a consequence of running thinner at Parallax).
I know you guys can figure this out much faster than I can, which would let me focus on the Blockly and Robotics Professional Development courses we're about to launch.
If somebody can do it I'd also need the XBee cellular module back when finished (but I'd happily thank you in other hardware).
It may have passed by the time the post is read, but there is a Webinar that describes the Digi XBee Cellular product right now:
globalspec.com/events/eventdetails?eventid=1177&evtsrc=MouserElectronics_170215_Inv1&et_rid=202350441&et_mid=83408027&cid=webinar
Although I would love to help out with getting XBee cellular up and running with Blocky, but I'm not sure if I have the knowledge or experience with Blocky to get this up and running for you. Sorry.
One note, the cellular carrier associated with this product is Verizon.
I was going to try out the XBee Kit if they had sent me one. But I don't have a need for it at the moment, so for $200 it can wait. :cool:
These are the latest coverage maps that I could find for the Verizon network, as in this contiguous US map, coverage may not be complete for each country.
The bottom map only shows that the particular country is investing in 4G LTE service.
When all else fails, this may get some attention. I have mine out of site and reach close to the road. Kind of embarrassing when a low sensor battery keeps it blaring till you get home.
Remind me to post a photo of the two I use...I got them from Radio Shack back in the day. Each has three (3) piezo elements in it, runs at 12V and is so loud that I can't be in the same room with it. Hurts my ears...very painful. But false triggers while developing the system forced me to install a quick-kill-switch as you can see on the prototype linked below.
http://savagecircuits.com/index.php/projects/basic-stamp-projects/19-prototype-alarm-system
How does it handle a triggered situation? Say a door is opened and closed. Does it halt on the event, and keep sounding the alarm, or is it still monitoring zones, and have a record of activity beyond the first text messages you receive. In other words, does it know any activity past the initial event.
What a great alarm system a Propeller would make. With it's multi-tasking ability you could protect a very large building, simultaneously monitoring multiple zones. And still notifying you of current conditions.
And the QuickStart would be a perfect board for the task. You could easily replace the large board that is in my system. And not have that learning curve it took to install it. If I ever have to make changes, I will have to go through that curve again.
We better get this thread back on track, Ken needs someone to tackle Blocky coding pertaining to XBee Cellular. If I was proficient in spin, I would be confident enough to take it on. Blocky looks easy enough after the librarys are established.
Apologies...this forum software does some very weird things...for example, Ken's message looks like a reply halfway down the thread to me, rather than the original post. To that end (getting things back on topic), please post your questions to my "wall" and I will answer them there.
It is a bit worrisome to have it tethered to one carrier. FWIW I'll link to another embedded modem compatible with the XBee footprint and interface, from the Nimbelink skywire. It can be an advantage to have a modem capable of dropping back to 3G service. Nimbelink also offers low-usage data plans.
No apologies needed, from my posts it looks like I had specifically posted this thread to deal with my problem.
Not the case, I just wanted to bring attention to the XBee Cellular product. And after talking to you, I relized that would be overkill for my needs. So you were not off topic, I was.
And if Ken see's promise in this product for Blocky development, I hope there will be more constructive input like Tracy's. As I said this is more than I need.
I had tried to get a price on the the product Tracy posted, but I come to the conclusion that it is locked into a plan with the manufacturer, with an option for direct carrier billing down the road.
I'm going to check out your BS2 project more closely Chris. As all I need is text messaging.
The XBee is 4G, Verizon only, it's not for me. I don't like the Verizon that much anyway.
https://starterkit.att.com/
Why can't you just use another carrier sim card that uses same technology as Verizon? I'll bet you could.
Not if the xbee cellular module has a provider lock on it- so that only Verizon sims can be used.
Although without trying a different SIM, who knows!!
In BlocklyProp, but one could understand the steps and code to use in other languages quite easily.
Are you thing about Telemetry transmission that the XBEE 900 does now?
If it senses the battery going low it can be set to retrace it's path incase there is land between it and home or just return to home. No radio link required.
