How is a Microcontroller’s Language Made?
AwesomeCronk
I have been bugged by this for ever. When you write PBASIC, the Stamp interprets it using whatever assembly language the interpreter PIC runs. But when you run the assembler language, what happens? Does it trigger a series of transistors inside the chip? And how is the assembler language made?
That's simplified explanation in a nut shell.
https://www.coursera.org/learn/build-a-computer
I think that the first half will answer your question. If you really enjoy this, then you can later get into FPGAs and build your own. Many more people seem to have an interest lately. I think that it's due to open source tools becoming available.
That book starts from first principles. Good read for you, but it may take a bit to really get going. If you can, power through some. It pays off.
In general, the assembly language gets made as a direct artifact of how the CPU gets made.
Instructions map to circuits that do the work. Some common things are always there: MOV, ADD...
Other things end up just happening as the design develops and ways to control it, or get work, data, to and from it become sensible.
There are also instruction sets that get mapped out ahead of time too. RISC V is one of those. CPU designs get made to perform the work the instructions require.
After the built in code stage, the IDE just has to read the keyboard and compile the right byte patterns?
What is with the wierd currency on the book’s webpage?
It's a very simple instruction set that, being open, can be used by anyone to create a processor, in actual silicon chips or as FPGA logic designs. You can read the technical description here:https://riscv.org/specifications/ It's short a sweet and pretty easy to understand.
Being an open specification it already has a lot of support from tool creators, like C compilers (GCC/Clang), Pascal (Free Pascal) etc, etc.
So far there are few actual RISC V chips one can buy. For example https://www.sifive.com/boards/hifive1 and
https://www.cnx-software.com/2018/10/19/kendryte-kd233-risc-v-board-k210-soc-machinve-vision/
This past year or so I have been busy learning Verilog and getting started designing my own RISC V processor core to use in in FPGA.
FPGA = "Field Programmable Gate Array"
Basically an FPGA is a chip full of digital logic that is configurable to create all manner of logic designs. Before you configure it it does nothing. You can reconfigure the same chip many times for different logic designs.
This all sounds horribly complex but at the end of the day one can use the software tools provided by the FPGA vendors to create your logic design. Either graphically, drawing AND gates FLIP-FLOPS and such, or by writing a logic description in a high level language like Verilog or VHDL. That's more like writing regular programs.
The biggest FPGA vendors are Xilinx: https://www.xilinx.com/products/silicon-devices/fpga.html and https://www.intel.com/content/www/us/en/fpga/devices.html
Lattice have some nice cheap FPGA that one can configure using completely Open Source tools:https://www.latticesemi.com/icestick
Typically a hobbyist would not by the chips directly but rather get a little development board. They can be very cheap, see that IceStick above.
When I was 14 I was tinkering with digital logic designs by soldering together lots of TTL logic chips: https://en.wikipedia.org/wiki/Transistor–transistor_logic. It's luxury today to be able to build complex logic with out all that hardware expense and soldering!
There are loads of FPGA turorials on the net now a days:
https://www.allaboutcircuits.com/technical-articles/fpga-tutorial-step-1-the-development-environment-and-hello-world/
https://numato.com/kb/learning-fpga-verilog-beginners-guide-part-1-introduction-a7/?utm_expid=.7ZBm96RhTSyo2rg6tZl_vQ.1&utm_referrer=https://www.google.com/
That speaks volumes. Thanks for the explanation. I think another word for "instruction" is 'opcode'.
I think I've heard that the P2 will be software based. By that explanation the P1, in contrast, has an instruction set that maps to hard wired circuits.
I'm not quite ready for an explanation of how the P2 architecture differs from that of the P1. I'll be watching and learning from the sideline.
Both the P1 and P2 are hardware based (using your terminology).
"Microcode". That helps.
I know SPIN produces 8-bit bytecodes that are fetched by the cog from the hub and executed in assembly. SPIN instructions can't be defined in terms of clock cycles because you can't predict where the hub pointer will be.
I'm getting closer. Thanks Mike.
