What is the L bit in the WAITX instruction and why can't I find it anywhere?
Peter Jakacki
in Propeller 2
I must confess to having some brain fog today but nonetheless I usually tend to muddle through it. Not so today as I was playing with some simple assembler words in TAQOZ and performing an automatic AUGD without having to use ## etc. But looking at the bit fields for the WAITX instruction I can't for the life of me think what that does again and neither can I find it explained anywhere in the documentation and of course forum searching is useless too.
This is your chance to say to me "it's simple!"
(which I'm sure it is).
I don't think any of the bit-field letters are labelled. Everyone just sort of gets the idea as they go.
Yeah, when I looked at the REP instruction I saw the I and L and thought it must be the immediate bit for the destination. Still though, it is not explained anywhere so I guess it should be noted in the first row of the instruction encoding column of the spreadsheet.
https://docs.google.com/spreadsheets/d/1usUcCCQVp3liAqENX9rvX-XVqJomMREhKYExM_taG0A/view
Edit: I should have read the rest of the thread before responding. @"Peter Jakacki", the copy I linked has exactly what you suggest (and I thought it's been there quite a while). Which spreadsheet are you referring to?
BTW - same spreadsheet but I was over in D1.
It was probably discussed eons ago, but lost in the wash.
