P2-Eval (64000-ES) first impressions — Parallax Forums
TubularTubular Posts: 4,771
edited 2018-12-28 03:37 in Propeller 2
I've spent my first full day with P2-Eval (part 64000-ES). Here are some quick notes before I wrap up
* Overall, a brilliant board
* Heat dissipation really good, the available area keeps things at most warm to touch
* Ground pillars great, really useful
Some rather minor issues relating to P2-Eval
* Measuring the 1v8 voltage isn't easy. Ended up making a kind of shunt jumper using a 2 pin stackthrough connector so could attach a probe
* Measuring 5v input current - it'd be nice to have jumpers like 1v8 and 3v3 rails have
* The micro USB connectors are 'upside down' compared with usual smartphone convention
* No reset transistor means operation is inverted compared to what we're used to with P1. ie it resets the P2 upon entry (rather than exit) from a terminal program. This is a pain for programs loaded in RAM (though not as much an issue for Taqoz, uSD/flash boot etc
* 1v8 adj pins not easy to use and could probably use a series resistor to limit adjustment range
* label the leds with their alternative function - RX, TX, MISO, MOSI etc
Some minor issues relating to P2 - will put in another thread after confirming them with others.
* PLL wobbles
* better VGA video out from 3v3 big switcher, compared to 3v3 low noise LDOs (why?[) its not; LDOs better
* HD vga timing
* PLL upper limits
  • Just had UPS delivered mine as they missed me the other day. The board looks great and we certainly know it's a P2 although I reckon Parallax should be splashed up there a little more prominently!
    I tried a uSD card and then I found it was super awkward for my fingers to grab hold of again to remove it. I had to put some tape on the end of the card as a pull-tab so maybe this is something that can be adjust mechanically for the next time.
  • The ES board won't mount the SD at anything beyond RCFAST or 20MHz clock setting. 30MHz kills it. I don't see any bulk caps near the SD socket either and those long traces could very well contribute to ringing.
    I will investigate further and get back about this.
  • Good find. Hopefully a strategically placed cap help fix it
    I'm reading up about the LDOs
    edited 2018-12-27 08:22
    it might have more to do with pcb trace capacitance since the I/O pins also go to the other side of the pcb as well as to the socket. The clock looks very rounded off.
    The CMD0 response seems to work at 120MHz though. (The lines with just a 1 or 0 are because I used a ^X to re-execute the last line entered).
    TAQOZ# 80 P2MHZ ok
    TAQOZ# 0 0 CMD . 1 ok
    TAQOZ# 1 ok
    TAQOZ# 1 ok
    TAQOZ# 1 ok
    TAQOZ# 120 P2MHZ� ok
    TAQOZ# 1 ok
    TAQOZ# 1 ok
    TAQOZ# 180 P2MHZ� ok
    TAQOZ# 0 0 CMD . 0 ok
    EDIT: Further tests now seem to mount at 70MHz but not 80MHz.
    I haven't tried any high speed SD access. May not get time before we fly to Adelaide tomorrow for 8 days for family get together.
    I always put a 100nF and 10uF caps at the SD power pins as close to the SD socket as possible. I found they were needed years ago as the SD cards required a lot of current in spikes.
  • The P2-ES clock is looking a little sad even at 180MHz. Perhaps somebody with a really fast scope can check this out too.
    422 x 202 - 8K
  • There seems to be a 4u7 cap next to the uSD, according to diptrace.
    I used to use 22uF but admittedly not a lot of science behind it
    It would be easy to parallel up the existing 0402 cap and see if it improves things. If you're feeling adventurous Peter, the cap is behind the molex uSD socket, between it and the flash chip, to the right. The left end of the cap is the VIO voltage. It should be possible to probe and see the voltage dip when mounting (since the other microsd socket pins are covered by the microsd card)
    563 x 484 - 34K
    edited 2018-12-27 09:56
    Those 0402 caps sure are small. Seeing that CMD0 is failing at medium speed leads me to think it has more to do with pcb trace capacitance. If I try a card on some other pins that aren't trying to run in both directions then I should be able to narrow down the problem.
  • I wonder whether resistive terminations might help, too
  • There is definitely no ringing since the capacitance must be quite large. In fact, I can write a little bit of code to probe the capacitance of each pin which I might do shortly.
    edited 2018-12-27 10:24
    Just a Q&D on the pins in regards to how quickly they float high again (note that P61 has a pullup)
    Interesting to note how the boot pins seem to have a lot of capacitance on them. I will also connect up a reference cap just so I can get an idea what this means.
    TAQOZ# : U.R     <# FOR # NEXT #> PRINT$ ;  ok
    TAQOZ# : ?PIN ( pin --  )
             ." P" DUP . 9 EMIT
             PIN L 100 us F
             CNT@ BEGIN R UNTIL CNT@ SWAP - ABS 10 U.R
             ;  ok
    TAQOZ# : ?PINS 62 0 DO CRLF I ?PIN LOOP ;  ok
    TAQOZ#   ok
    TAQOZ#   ok
    TAQOZ# ?PINS
    P0      0009212096
    P1      0007412456
    P2      0003025976
    P3      0007411496
    P4      0001332056
    P5      0007367096
    P6      0000486416
    P7      0006839576
    P8      0008339216
    P9      0007840856
    P10     0007900496
    P11     0007490336
    P12     0002984696
    P13     0007790336
    P14     0003848816
    P15     0002530016
    P16     0009377456
    P17     0009101936
    P18     0008730776
    P19     0008374016
    P20     0008725016
    P21     0008310896
    P22     0007427096
    P23     0008241296
    P24     0006275936
    P25     0007353536
    P26     0000646736
    P27     0003584096
    P28     0001111016
    P29     0008386496
    P30     0001767176
    P31     0007808096
    P32     0007926416
    P33     0007786376
    P34     0008354696
    P35     0007804136
    P36     0008359016
    P37     0007992416
    P38     0008161856
    P39     0007449176
    P40     0007458296
    P41     0006984656
    P42     0006080816
    P43     0007120256
    P44     0007244336
    P45     0003085016
    P46     0006141776
    P47     0004675016
    P48     0009187976
    P49     0004548656
    P50     0008700776
    P51     0005089736
    P52     0008358776
    P53     0008215496
    P54     0008423816
    P55     0008633816
    P56     0014658536
    P57     0013100456
    P58     0044194136
    P59     0021615056
    P60     0032916296
    P61     0000000176 ok
    TAQOZ#
    Running the same test averaged over 8 samples confirms that P58 is abnormally loaded.
    P55     0010117159
    P56     0017411809
    P57     0015647914
    P58     0073298419
    P59     0028579759
    P60     0032337739
    P61     0000000184 ok
  • Really neat work, Peter.
    These kind of diagnostics that P2 can perform are going to come in very handy over the years ahead
  • evanhevanh Posts: 17,163
    edited 2018-12-27 11:15
    Looks like you got something there Peter. P58 is the longest track of all, by a decent margin.
    As well as running up to V5663 connector, the track goes around far side of 3v3 regulator, over to V4047 connector and all the way down outside edge of board and right around the SD connector and back into SPI flash chip.
    And also has 240R resister to MISO pin of SD card. So the SD card can't drive it as hard.
    1571 x 1561 - 201K
    1661 x 1655 - 292K
    Actually, P61 is similar track length to P58. You might want to see what's going on with the test result of P61.
  • High speed SD was one of the things I was hoping to test on the ES board....sigh.
  • You still can, just using an add on board.
    It sounds like that 240-ohm MISO resistor needs to be lowered to half, or less.
  • samuellsamuell Posts: 554
    edited 2018-12-27 19:35
    Tubular wrote: »
    You can measure the 5V current either by using a test jig for USB current measurement, or by doing some calculations.
    There is no convention regarding micro USB connectors. Some are to be mounted "upside down" and some aren't. As long as as the body pads are not SMT, it is good enough for me.
    As for the lack of an inverting transistor to control the reset pin, that is good to know. Thus, it is possible to access the serial terminal with PuTTY or any conventional TTY com program. If you noticed, the serial output from the Activity board is not correctly visible (that is, the program is not seen starting up from the begining) via PuTTY or via HyperTerminal. That is due to the inverting transistor that exists on that board. Doing the same mistake here would be... well, a mistake.
    To add, IMHO programs should be reset on entry rather than on exit. Doing otherwise would cause one to miss information that the program outputs after establishing a connection. Programs loaded on RAM are not much of an issue, since they will need to be loaded via some IDE anyways. The IDE could reset the interface after, as an option.
    Kind regards, Samuel Lourenço
  • Hi Samuel
    Just to be clear those minor observations I made were just that, minor, and no big deal, and there are workarounds. Overall this is a really useful board
    I'm not sure of the problem you refer to with the activity board. Is there a link with further information? Using the reset transistor has been a long tradition (every prop plug has one, too).
    Yes, a tightly integrated IDE that kept the port open between loading the program, and viewing results in a terminal, would solve the problem, but we don't have that. Even Prop tool had separate PST
  • jmgjmg Posts: 15,200
    Looks loaded alright. A 50% clock duty cycle can help and a well placed NOP can tolerate more slew on the paths.
    That increases the sysclk, but at the expense of highest possible SD MHz.
    Maybe the boot code need to be tuned as 'more tolerant', rather than 'fastest' ?
    Can some of the long meander trace be isolated, to reduce the load ?
    edited 2018-12-27 19:55
    Hi Tubular,
    If you load my prime number program onto the Activity Board (or a simple "Hello World" program, for that matter), you will notice that the prompt (or the message) is not visible via PuTTY or HyperTerminal, because the Propeller is not reset once the com starts. SimpleIDE works OK, since it toggles !RTS or !DTR. On other terminal programs, these pins (on the FTDI chip) stay low during comunication, and stay high if no comunication is established.
  • VonSzarvasVonSzarvas Posts: 3,634
    edited 2018-12-29 14:26
    Couple thoughts about the reset topic...
    1. FTDI programming allows all the signals to be inverted, such as DTR
    2. If you are using a Microsoft OS, then Reset upon entry is most likely caused by the way the OS negotiates the port by default. It always toggles DTR in search of the old serial mouse. The behaviour can be disabled in device manager / properties. After that, you should be able to plug in P2 without experiencing any reset at all. (I'm being a bit vague here, as this is from memory. I'll be in the office tomorrow, and could share the OS setup doc if that would help anyone).
    About SD...
    When the add-on boards arrive, there will be a mini protoboard in the set, onto which the Parallax SD card socket could be attached. This would allow SD experiments at high speed from one of the non-boot pins. I've made a note to add this "step-by-step" to the upcoming add-ons docs.
    About the Protoboards
    There will be a mini and full-size protoboard. Someone earlier mentioned having a breadboard connection. @JonnyMac I think. That could be achieved a couple ways with the protoboards. And with the full-size proto, one could solder headers to the 2 outside columns, and then you get the perfect size between to stick a mini-breadboard. The pictures and details will be shared soon after Jan 2, as the docs are being created at the moment.
    samuell wrote: »
    Tubular wrote: »
    A rough 'convention test' is to check Digikey stocks.
    Cheapest, and highest volumes are what P2 Eval has, 240k, 20c/1200
    'Reverse' tagged micro-usb are lower stocks and higher prices 43k, 48c/2k
    There are bypass caps on P59 and a few other pins to overcome the effects of the silicon race condition that causes some pins to dive low before floating, when OUT=1 and DIR=fall. Those caps would certainly load those pins. They can be removed, of course. In the case of P59, it will then be necessary to select the pull-up via the DIP switch.
  • I have this problem with a lot of Parallax boards and the only one doing it right is/was the Spinnerette with a jumper to disconnect reset. Plugging in usb and the propeller resets. plugging some other stuff into USB, windows enumerates the ports and the connected propeller resets, update and/or restarting windows and the propeller resets, on some boards even USING the serial FTDI port without any USB/PC connected resets the propeller.
    If you need to keep your propeller board running without all this hassle requires to cut some traces and add a jumper or switch for programming/run. When Parallax was using a Propplug and not in build FTDI one could overcome this easy with a small adapter not connecting /RST, just put a three pin header in between and done.
    Might not be such a big problem for a evaluation board but since the demise of the Protoboard w/o USB there is no Parallax board not resetting when plugging in a USB connection to a PC.
    Witch is simply wrong if you need to check on a running system.
    What I also miss is a simple power switch. Disconnecting the USB cable seems odd to me.
    Enjoy!
  • msrobots wrote: »
    This seems like the same settings issue for the com port. There are 2 things to un-tick in the com port properties, then you shouldn't get resets on most (if not all) the boards.
    I'll share the step-by-step doc tomorrow. At least hopefully it will help improve some things.
    edited 2018-12-27 20:54
    VonSzarvas wrote: »
    2. If you are using a Microsoft OS, then Reset upon entry is most likely caused by the way the OS negotiates the port by default. It always toggles DTR and RTS in search of the old serial mouse. The behaviour can be disabled in device manager / properties. After that, you should be able to plug in P2 without experiencing any reset at all. (I'm being a bit vague here, as this is from memory. I'll be in the office tomorrow, and could share the OS setup doc if that would help anyone).
    Hi VonSzarvas,
    If I recall correctly, there are no toggles on the !RTS and !DTR lines. I've confirmed that with PuTTY on Windows/Linux and with HyperTerminal on Windows. The FT230X !RST line goes down when the com starts, and stays there until it ends. The FTDI chip on the Activity Board behaves the same way.
  • VonSzarvas wrote: »
    Just confirming this, plus a power reboot, fixes the issue. Many thanks
    Two different issues are being mixed here...
    The transistor to invert the DTR Reset is to overcome switching between programs on Windoze. This is due to separate programs rather than a complete IDE. When Windoze switches between a running program and starts a new program, DTR is cleared. If the outgoing program had DTR set, this causes a Prop Reset. Now, if DTR is inverted by the transistor, a Prop Reset does not occur, which is the desired outcome.
    Tricks using capacitors etc work mostly, but they only hide the underlying problem. The transistor CCT solves a Windoze bug and a non-integrated IDE.
    IMHO the transistor cct should be retained, but it should be on the Prop board, not on the PropPlug or other USB serial board. All my P1 pcbs for years have had a linkable transistor reset cct.
    Plugging in a USB with an FTDI causing reset, and other similar reset problems, are due to the P1 powering up the FTDI chip thru the I/O pins. This is a totally different problem.
  • TubularTubular Posts: 4,771
    edited 2018-12-28 03:00
    Ok on the "VGA video quality vs selected voltage regulator front"
    I'm pleased to say I had the sources mixed up, and the 8 small LDOs do indeed result in better video quality than the big 3v3 switcher.
    I was mixed up due to the labeling. There is a current measuring jumper with "VIO" on one side and "3V3" on the other. Due to the orientation I believed 3v3 to be the rail going to the P2, but it is in fact the VIO side connected to the P2.
    At the jumpers, "3V3" refers to local 3v3 LDO outputs, and "VIO" refers to main 3v3 big switcher.
    The jumpers as shipped (at least on mine) were connected to the big switcher (jumpers closest to central axis)
    I did some experiments with multiple local 47 ohm 1/4w load resistors from V0003 to ground. When running from the big switcher, 1 x 47 ohm resistor load made streaking slightly worse (than zero resistors), but keeping going and 4 x 47 ohm resistors made things good (similar to local LDO)
    There is a glitch in the main voltage rails, both 1v8 and 3v4, 4 times per video scan line, synced to the scan line.
    I need to revisit PLL supply and take some further measurements
