P2 DEVICE DRIVER ERROR
pilot0315
in Propeller 2
Device not found. Any ideas. I have downloaded the files from parallax that has the examples and the Pnut. I am running windows 7.
See attached.
Thanks.
See attached.
Thanks.
Re-installing the P1 Prop Tool can install the drivers...
Install, restart, plug device in. Windows should load the driver at that time.
From there, it should recognize the devices with no prompts.
the com port.
It was suggested that I use the parallax serial terminal with the Pnut. Is there anything special that I need to do
to link the two??
May reconsider for P2.
I have also looked at other suggested ide's but am having trouble getting them to work.
Also do you have a P2 pasm example that makes the lights continue to blink. I am note sure the
example from parallax is working. Two light stay on the go out. Do I need to scope them to see the
blink?
I think the other IDE's need loader fixing to work with new eval board...
I should get a board today. As more of us ramp up, there should be some code to mooch.
If I were you pilot, post up what you got. We can help.
Do not worry about quality, etc.. nobody will care. We want to get going on the P2. Lots to show and tell over the next few months.
This should blink P58.
All good
Martin.
Also puts me on the path.
Do there is no try.
