What clock speed are you running?
potatohead
                                  in Propeller 2
                    My board should arrive Monday sometime.  Since some of you are up and running, or have boards and are getting setup, I thought it would make sense to see what speeds everyone is running.
Peter posted some additions to TAQOZ to allow speed changes in this thread:
https://forums.parallax.com/discussion/167868/taqoz-tachyon-forth-for-the-p2-boot-rom
BTW, any idea on how to post a link directly to a comment instead of just the thread?
Edit:
Thanks to Cluso here is a direct link: https://forums.parallax.com/discussion/comment/1458952/#Comment_1458952
C.W.
R-click on the time in the post you want, then copy the link. Easy once you know the secret
Thanks for the tip Cluso! I would not have found that on my own.
C.W.
UPS just rang to confirm the address so it sounds like I will have a P2-ES soon as well. I will test some code on that as soon as I get it and post it and the results on the TAQOZ thread later.
I did a test a couple of weeks ago trying NTSC video output off the RCFAST oscillator. It was a bit wobbly, but text was quite legible. RCFAST seems very stable. It will be interesting to see how much RCfast frequency varies from chip to chip
Room temp is 35C (95F) and board temp is same as ambient. (no fan).
Kind regards, Samuel Lourenço
