USB Micro Male Connectors
JonnyMac
Looking for a USB micro male connector that I can solder to -- just need it for power, but device is in a very tight space hence standard cables are problematic.
Or, there are 90' cables ?
You might try one of those tiny USB Wifi, Bluetooth or microSD plugs. They are extremely small. Just solder your power cable to the correct pins and cut the pcb tracks to all pins so there is no connection to whatever is on the pcb.
Postedit: Oops, missed the micro part
https://www.sparkfun.com/products/12035
https://www.amazon.com/diymore-Micro-Connector-Plastic-Cover/dp/B01KV4RANE?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ftas-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B01KV4RANE
https://www.digikey.com/product-detail/en/hirose-electric-co-ltd/ZX20-B-5S-UNIT-30/H125237-ND/5994703
