Looking for a USB micro male connector that I can solder to -- just need it for power, but device is in a very tight space hence standard cables are problematic.
Jon,
You might try one of those tiny USB Wifi, Bluetooth or microSD plugs. They are extremely small. Just solder your power cable to the correct pins and cut the pcb tracks to all pins so there is no connection to whatever is on the pcb.
Check Avnet, Mouser or Digikey ooops. wrong gender. edited. check also tyco electronics. i know they make (and I have) a mini, but not sure of micro male plug.
Or, there are 90' cables ?
Postedit: Oops, missed the micro part
https://www.sparkfun.com/products/12035
https://www.amazon.com/diymore-Micro-Connector-Plastic-Cover/dp/B01KV4RANE?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ftas-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B01KV4RANE
https://www.digikey.com/product-detail/en/hirose-electric-co-ltd/ZX20-B-5S-UNIT-30/H125237-ND/5994703
