Get individual characters from integer value
in Propeller 1
Hello everyone. I feel like this should be simple, but I do not know how to do this in spin.
A value is being sent via a serial port in the following format: "B12345," (I'm using the Extended fullduplex serial so , is the delimiter.)
I am then taking everything after the first character and converting it to an integer. So the integer will equal 12345. I need to split this integer into 5 different variables equaling 1, 2, 3, 4, & 5. How do I go about this?
Here's my code:
testVar is equaling 12345 so I know the conversion is working properly. I just need to get digit1, digit2, etc to equal 1, 2, 3, etc.
Thank you in advance.
Here's my code:
PUB readSerial | type, content, contentAdr, value, b repeat readBuffer := "0" serial.rxflush repeat until readBuffer <> "0" serial.RxStr(@readBuffer) type := readBuffer 'Take first character of string sent from computer to see type content := readBuffer[1] 'Take everything after the first character to get content contentAdr := @readBuffer[1] if type == "A" if content == "1" winValue := 1 elseif content == "2" winValue := 2 if type == "B" value := 0 ' reset value repeat b := byte[contentAdr++] ' get digit from string if ((b => "0") and (b =< "9")) ' if digit value := value * 10 + (b - "0") ' update value else quit testVar := value if testVar == 12345 serial.str(string("matches/")) else serial.str(string("not a match/")) update(@digit1, @digit2, @digit3, @digit4, @dp)
Why not just subtract "0" (= 48) from all nonzero bytes in the string to get a string of 5 values of 0 to 9 and pass these bytes to your update function?
i=1
digit = string-48
value = 10*value + digit
loop until your at the last character of string[]
Andy
Thank you so much.. This worked great.
