Is there a trick to linking to old posts?
in Propeller 1
These are links that result in "page not found" errors. For example thread 601870 contained basic help on P1ASM. Is it still "somewhere" that can be linked to or is it gone forever?
Thanks (and hopeful)
Tom
Tom
Thanks that worked.
Tom
You can also use a google or google powered secure search engine like startpage, but sometimes google blocks services like startpage.
Sometimes you must go directly to the google search engine put the following in the search box.
Then in the search box I put:
So if I want to search for spdif on the forums, i could use.
For instance, take an old link like this one:
http://forums.parallax.com/showthread.php?t=109665&highlight=emulators
t=[Number] => is the discussion number in the new web.
Instead, turn the URL into:
http://forums.parallax.com/discussion/[Number]
Et voila ! make "parallax old news" great again.
http://forums.parallax.com/discussion/109665
I wonder why web admins didn't roll a script to the database to change them.
I'm one of those that the forum search is completely dead. It never returns anything.
you're not missing out on much. Google outperforms pretty much any forum's built-in search on a keyword search. While most forums have a nice parametric search to make up for it, this one sadly doesn't.
