I See Two USB Ports on the P2 Eval
AwesomeCronk
in Propeller 2
What are they for?
The other is the normal USB serial connection (via FTDI chip) to pins 62/63 for programming/etc.
No, both USB connectors can power the board.
https://www.amazon.com/gp/product/B074KHX8CP/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Especially if you are going to hang daughter boards off of it with more chips needing power.
Publison, it's interesting how the main title of that amazon link says 3A, but the description text below says 2.5A.
I think that depends how ambitious you are... FWIR 100mA is default and 500mA is easily configured on most USB interfaces.
However, P2 can draw above what those can deliver.
Generic cables may struggle even with 500mA.
Good idea.
I wonder if Parallax used highest current spec'd USB connectors ?
When you get to 2/3.5/3A not everyone agrees on who can carry what current
Digkiey specs variously 1A / 1.5A / 1.8A /
1.8A looks like the industry default, (for cheapest/highest volume stocks) which should be OK for P2
Wurth Electronics Inc. 629105150521 specs 1A/3A, but comes at a relatively high price. It does spec 30 mΩ max & has nice solid looking body-pins.
A good cable, with proper copper conductors, is likely to have most influence. Fatter copper on the PCB on GND/PWR can only help too...
By Jove, I think you are right! I can't zoom the see the actual printing.
