Data over power
in Propeller 1
I need someone to please point me in the right direction. old thread, link to an article, or any helpful info at all. I have two propellers about ten feet apart both being powered by a 12v 77A DC power supply and I want to send data over the power line similar to a phone line, half duplex is fine if that's all that is possible.
Thanks in advance for any help.
https://www.smarthome.com/sc-what-is-x10-home-automation
You can also search the internet and this forum for X10, which is the the first popular communication protocol over power lines. Still in use today. There are also power line modems available.
The power line you are referring to is 12VDC? Correct? If so you might be able to couple your data signals into the power with DC blocking Caps. How fast is your data going to run?
Jim
Your first post mentions the current is 77A. Is that correct or is it a typo? Is it the supply rating or actual current draw?
I ask because I designed a relatively simple power line comm for a long conveyor that may work for you.
That's quite a difference - 77A to 1A ?
The main challenge with power+data is to raise the impedance enough at some frequency, to get enough voltage swing to measure...
A series inductor for each end is common, but it needs to be rated at the supplied current.
IrDA has examples of Serial to pulse and pulse to serial usage, there is bound to be some IrDA code for P1.
The other issue, is what does the current draw by the system look like, frequency wise. You want to avoid lots of energy where you are trying to send data ....
http://forums.parallax.com/discussion/110918/bell-202-modem-1200-baud-afsk-object/p1
It's only 1200 baud, though.
and inject the signal in one component. PoE does this with beefed up magnetics for instance.
And you get isolation of course.
Getting the right transformer is crucial, it has to handle the DC bias current without saturating.
The AC signal needs to use a DC-free modulation technique.
For low voltage other approaches using RFCs and capacitor injection may be cheaper - you still need to handle
the DC current without saturating, you get less isolation, you need DC-free modulation. This
may be easier to source.
Check it out, i have adapted the method to make my own data over power in the past, simple hbridge pushed by serial output , two wires, ...etc..
My dcc equiptment can be set to 12v. I doubt op needs 77amps tho?
https://www.nmra.org/beginners-guide-command-control-and-dcc
https://www.nmra.org/sites/default/files/standards/sandrp/pdf/s-9.1_electrical_standards_2006.pdf
