*NEW*PowerPal Selectable Voltage 3-Amp Breadboard PS
Publison
                    The latest product from Parallax: https://www.parallax.com/product/32133
Publison
I would also like this unit to have a power switch like the one that's on the BadgeWX that you can push to turn it on and off with an LED to tell you it's on.
I just use a USB supply (5 volt 2 AMP) to supply input to the module and also supply one of my busses.
The 5A 5V supply for the RPi works well for providing 5V for circuits and powering a 3.3V regulator.
What is worse, this means I also have to be good until then...
Rev, that can't be too hard for you.
