Problem with Multicore Programming
in Propeller 1
Hi,
I'm trying to read gyroscope and accelerometer data in a second core and print the values from that same core. However, the outputted values are all the same when I try to run in a different core. The same block of code that reads the sensors works perfectly fine when run in core 0. My code is posted below. Please help.
Test Multicore
#include "simpletools.h" // Include simple tools
// Variables for gyro
volatile signed int whoAmI;
volatile signed int xL, xH, yL, yH, zL, zH;
volatile signed int statusReg;
volatile float gx, gxSum, gxAvg, gy, gySum, gyAvg, gz, gzSum, gzAvg;
// Variables for accel
volatile signed char x, y, z; // Z-axis value, *must be a signed char*
volatile int axSum, axAvg, xOffset, aySum, ayAvg, yOffset, azSum, azAvg, zOffset;
// Gyro pins
volatile int CS=11;
volatile int SCL=10;
volatile int SDA=9;
unsigned int stack[40+25];
int cog;
void data();
int main(){ // Main function
// get gyroscope initializations
high(CS); //CS line high (SPI inactive)
low(SCL); //CLK line low (prepares chip to send brief high signals or clock pulses)
low(CS);
shift_out(SDA, SCL, MSBFIRST, 8, 0b10001111); //Send read register address (whoAmI)
whoAmI = shift_in(SDA, SCL, MSBPRE, 8);
high(CS);
if(whoAmI == 0b11010011){
print("Device ID Correct: %b\n", whoAmI);
else{
print("Device ID Incorrect: %b\n", whoAmI);
//Register 4 - Set 3-wire SPI
low(CS); //CS line low (start SPI)
shift_out(SDA, SCL, MSBFIRST, 8, 0b00100011); //Write MCTL register (register 4)to set 3-wire SPI
shift_out(SDA, SCL, MSBFIRST, 8, 0b10010001); //Value for MCTL register (register 4) to set 3-wire SPI
high(CS);
//Register 1 - Set 100Hz output rate, 25Hz cutoff freq, normal mode, enable all axes
low(CS);
shift_out(SDA, SCL, MSBFIRST, 8, 0b01100000); //Write MCTL register (register 1)
shift_out(SDA, SCL, MSBFIRST, 8, 0b00011111); //Value for MCTL register (register 1)
high(CS); //CS high(stop SPI)
// get accel initializations
high(6); // CS line high (inactive)
low(8); // CLK line low
low(6); // CS line low (start SPI)
shift_out(7, 8, MSBFIRST, 8, 0b10101100); // Write MCTL register
shift_out(7, 8, MSBFIRST, 8, 0b01100101); // Value for MCTL register
high(6); // CS line high (stop SPI)
pause(100);
simpleterm_close();
cog = cog_run(data,128);
//cogstart(data, NULL, stack, sizeof(stack));
void data(){
simpleterm_open();
while(1){
// get gyroscope data
// x-axis
low(CS); //CS low selects chip
shift_out(SDA, SCL, MSBFIRST, 8, 0b10101000); //Send read register address (OUT_X_L)
xL = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
high(CS); //De-select chip with CS line high
low(CS);
shift_out(SDA, SCL, MSBFIRST, 8, 0b10101001); //Send read register address (OUT_X_H)
xH = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
high(CS);
gx = (short) (((xH<<8) | xL)-gxAvg)*.0175*PI/180;
// y-axis
shift_out(SDA, SCL, MSBFIRST, 8, 0b10101010); //Send read register address (OUT_Y_L)
yL = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
low(CS);
shift_out(SDA, SCL, MSBFIRST, 8, 0b10101011); //Send read register address (OUT_Y_H)
yH = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
high(CS);
gy = (short) (((yH<<8) | yL)-gyAvg)*.0175*PI/180;
// z-axis
shift_out(SDA, SCL, MSBFIRST, 8, 0b11101100); //Send read register address (OUT_Z_L)
zL = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
low(CS);
shift_out(SDA, SCL, MSBFIRST, 8, 0b10101101); //Send read register address (OUT_Z_H)
zH = shift_in(SDA, SCL, MSBPRE, 8); //Get value from register
high(CS);
gz = (short) (((zH<<8) | zL)-gzAvg)*.0175*PI/180; //2's complement operation, subtract zero rate offset, multiply by
//sensitivity value for 500deg/s, "short" needed for 2's complement
print("gx = %f gy = %f gz = %f\n",gx*180/PI,gy*180/PI,gz*180/PI);
// get accel data
//x-axis
low(6); // CS low selects chip
shift_out(7, 8, MSBFIRST, 8, 0b00001100); // Send read register address, z-axis
x = shift_in(7, 8, MSBPRE, 8); // Get value from register
x = x-xOffset;
float ax = (float) x;
ax = ax/64;
high(6);
//y-axis
shift_out(7, 8, MSBFIRST, 8, 0b00001110); // Send read register address, z-axis
y = shift_in(7, 8, MSBPRE, 8); // Get value from register
y = y-yOffset;
float ay = (float) y;
ay = ay/64;
high(6);
//z-axis
shift_out(7, 8, MSBFIRST, 8, 0b00010000); // Send read register address, z-axis
z = shift_in(7, 8, MSBPRE, 8); // Get value from register
z = z-zOffset;
float az = (float) z;
az = az/64;
high(6); // De-select chip
// print("ax = %f ay = %f az = %f\n",ax,ay,az); // Display measurement
Thanks for your response. I am confused because there is no while loop in main so doesn't it just run through main and stop when it gets to the end?
while (1) ;That worked! Adding initializations to the data core is what I needed to do. Thanks very much.
David,
Unfortunately adding the while loop to main didn't work, but thanks so much for the suggestion.
Otherwise you get:
