Number to time(s) one can GET and PUT to the scratch pad memory on the Basic Stamp SX.
denno
Yes, I know the BS2sx in not out there anymore. But, I have several of them running for years now. 12 years to be exact...
So, the subject line says it all, but I will repeat....In program slot 0, I PUT a variable in stratch pad memory, position 1. Then in another program slot I GET that variable for use. This has been going on for about 12 years, 24/7. Do you experts, think that I have wore out that scratch pad memory position and should pick another location to put that variable. Easy to do.
The reason I know something is amiss is I am not getting the jump to a picitular speech output, using the EMIC voice, which involves that PUT/GET 0 or 1....at that location.
Any thoughts....? DenO
