Problems to combine two boards: WX Activity and Human Interface
in Propeller 1
Hi,
I wanted to output VGA signals from my Activity board (Pin 8 -15) to the Human Interface Board (Pin 16 - 23).
So I simply connected the pins and started TV_Demo.spin with basepin 8.
But "nada" no VGA-output, not even a blinking LED (16-23 are wired to LEDs, too)
I tested, if current is ok - and yes it is, Human Interface Board has its own power supply and Activity Board is connected with USB from PC.
Are ther more pins of the Human Interface Board to connect ?
Please help .
Please help .
You need VGA_Demo, I think.
Can you light the LEDs using DIRA/OUTA?
But now I connected both VSS-Pins from Human Interface Board (Nr. 9 and 29) with GND of Activity Bord.
Tetsted with DIRA/OUTA.
And it didn't work either...
You said the HIB has it's own power, so that resolves the other question that also came to mind because the HIB has a video amp chip for the VGAs RGB lines.
Can you upload a pic of the setup? Here's a copy of the cheat sheet I made for me....
You saved my day.
First I didn't know, that I had to connect Pin 39,40 of the Human Interface Board with its Auxiliary I/O header Pins,
to see anything on the LEDs.
Then there was this wrong pin-layout (17-24) instead of (16-23).
So I connected PIN 8 - 15 of the Activity Board with PIN 17 -24.
Another connection of GND (Activity) to PIN 9 (Human Interface) was necessary too.
Both board had their own power supply.
But now it works.
Thank You for your help !
