4 Channel Triac Driver
Hello all,
Would someone who is far better at assembly than me and has a little free time be willing to write a driver object for a 4-channel triac light dimmer such as this: https://www.amazon.com/dp/B06Y1W12XC/ref=cm_sw_r_cp_api_CgLZBbA3M6GN7 ?
One sync pin for all channels, and separate opto pin per channel.
Thanks!
Will post the project the object will be used in once it’s complete.
Thanks!
If I’m reading the code correctly, it auto-determines both Hz and whether the pulse is positive or negative?
Thank you, sir!
Thank you again
