Need help with DAC / streamer configuration — Parallax Forums
Hi All
I'm converting some old FPGA code to real silicon.
I had a 4 bit R2R ladder on pins 11..8 on the FPGA which I streamed data to.
This works great!
I now want to switch to internal pin DAC.
I'm not having much luck.
Need someone with fresh eyes to find my mistake.
con
	use_dac = true	'false = r2r,true = pin dac
		xtal = 12_000_000
		dv = xtal / 1_000_000,mlt = 80	'80MHz
		sys_clk = xtal / dv * mlt
		clk = 1 << 24 | (dv-1) << 18 | (mlt-1) << 8
dat		org
		hubset	##clk | %1111_01_00
		waitx	##20_000_000/100
		hubset	##clk | %1111_01_11	'80mhz clock
		qfrac	##10_000,##sys_clk << 1
		getqx	pa
		setxfrq	pa			'set streamer freq to 10kHz
		mov	pa,##use_dac wz
	if_z	setnib	dira,#$f,#2		'4 bit r2r ladder P11..P8
	if_nz	wrpin	##%10100_000000000_01_00000_0,#8  'DAC mode
	if_nz	dirh	#8
loop		getct	pa
		addct1	pa,##sys_clk / 2
		waitct1
		rdfast	#0,##$400
	if_z	mov	pa,streamer_r2r
	if_nz	mov	pa,streamer_dac
		add	pa,##sample_end-sample
		xcont	pa,#%00110
		jmp	#loop
streamer_r2r	long	%0001_0000_1001_0000 << 16  'rfbyte 4 bit reorder ,pins 39..8
streamer_dac	long	%0001_0001_0000_0000 << 16  'rfbyte 4 bit reorder , output X0 on all four DAC channels
		orgh	$400
sample		file	"ufo_killed_sound.dat"
sample_end
  • jmgjmg Posts: 15,194
    PeterJ has VGA from P2 silicon working, and that uses this XCONT opcode (same as your loop), so you could see his setups ?
    XCONT {#}D,{#}S Buffer new streamer command to be issued on final NCO rollover of current command, continuing phase.
  • I've already have VGA and NTSC running on my setup fine.
    Try this:
    dat		org
    		hubset	#%1000
    		hubset	#%1010
    		wrpin	##%10110_00000000_01_00000_0,#0  'DAC mode
    		dirh	#0
    		rdfast	#1,##sample
    		setxfrq	##$8000_0000
    		xcont	streamer_dac,#%00010
    		jmp	#$
    streamer_dac	long	%0001_0001_0000_0000 << 16 + $FFFF  'rfbyte 4 bit reorder , output X0 on all four DAC channels
    		orgh	$400
    sample		long	$76543210,$FEDCBA98
    You had 9 zeroes in your DAC-value field, where you should have had 8.
    Something seems strange, though, because every other output update, the top nibble of the DAC value seems to go to %0000.
  • Thanks Chip!
    That fixed it.
    I see what you mean about the alternate nibbles.
    800 x 480 - 77K
    DAC.jpg 77.2K
    If you put bit 7 of the mode high, it works, but that enables the pins, too. Try that.
    edited 2018-10-21 06:48
    It looks like there is a bug in the shifter. The FPGA is doing it, too. Good thing you found this!
    Set bit 23 of D high in the streamer command. That sets the pin-enable bit high.
    I've got the pin and DAC data tangled up. They need to be separate.
    edited 2018-10-21 07:07
    Here's Bit 7 set of the mode.
    That's better :smile:
    800 x 480 - 82K
  • Woot, the more bugs we find now the better, right?
    edited 2018-10-21 08:24
    Roy Eltham wrote: »
    Absolutely. I've been looking and looking at the related Verilog and I know what signal is causing the problem, but not how it's causing it.
    edited 2018-10-21 08:35
    Okay. I see it now. Lucky it worked, at all, without bit 7 being set. Bit 7 enables the pins, but in case you don't want the pins and you set that bit low, it clobbers the DAC data, which may still have been wanted. I need to figure out how to untangle this.
  • Chip
    I switched back to streaming direct to the pins and the data doesn't appear to exhibit the alternate 0000's issue, if that helps.
    800 x 480 - 95K
    ozpropdev wrote: »
    Chip
    Yes, it just happens to the DAC data when the pins are disabled by bit7 being low. So, for now, if you want to stream to the DAC, you'll have to enable the pins (bit7 high), but park them somewhere you're not using pins, and then keep their DIRs low.
  • cgracey wrote: »
    ozpropdev wrote: »
    Chip
    Roger Wilco.
  • evanhevanh Posts: 16,796
    You've got me trying to make sense of the pin control in the mode setting now:
    The "PAD_IO Modes" sheet has two tables. The left hand table I think I've got a handle on, but the right hand table I've really struggled to work out where it fits in.
    edited 2018-10-21 11:14
    evanh wrote: »
    The right hand table breaks down as follows:
    Column "CIOHHHLLL" shows what bits are flexible and which are held in fast states for all the modes.
    Column "OE" shows what signal controls the digital output enable. It's always DIR, except in the case of the DAC modes, where it's 0 (off).
    Column "DAC" shows when the DAC output is enabled. It's only on when in DAC mode and DIR is high.
    Column "ADC" shows when the ADC is enabled. In DAC modes, OUT enables ADC (DIR must be high, too).
    Column "ADC Mode" shows the ADC mode settings for ADC and DAC modes. For DAC modes, it's fixed at %011 which is "PinA 1x".
    Column "Comp" shows what modes the comparator is enabled in and what its inputs are.
    This table was made for my own use in the schematic software where the I/O pin was designed.
    Does the right hand table exactly map on to, line for line, to the left hand table?
    edited 2018-10-21 12:17
    Here's a question about the left hand table: PinA and PinB aren't the same 'A' input and 'B' input in the smartpins are they? I'm guessing PinA and PinB are even/odd, respectively, pin pairs.
    evanh wrote: »
    Yes.
    evanh wrote: »
    Right. PinA is that very pin. PinB is its even/odd neighbor.
    I'm curious why PeterJ's VGA code does not seem to have this effect - is that Streamer-LUT-DAC use a different-enough pin mode to miss this issue ?
    jmg wrote: »
    It only happens on 4/2/1- bit DAC output modes.
  • The doc's/tables also need to include
    WRPIN ##%101xx_0000cccc_01_00000_0, #dacpin 'select cog %cccc's DAC channels
    Where %cccc = cog from which DAC data is coming.
    evanh wrote: »
    Doh, of course, PinA can be either even or odd. :)
    edited 2018-10-22 01:06
    ozpropdev wrote: »
    Yah, that's difficult to document in a clean fashion. It triggers on that combination of %101 dac mode and %01 pin source.
    PS: I wonder what will happen if used in the smartpin DAC modes, as in
    WRPIN ##%101xx_0000cccc_01_00010_0, #dacpin 'select cog %cccc's DAC channels
    EDIT: Sorted, that is output enable control for all smartpin modes.
    Okay, next question: %TT = %10, BIT_DAC mode. I'm guessing this requires two WRPIN setups instructions. One for setting the DAC level and second one to set this mode.
    I think its purpose is to make OUT toggle the output between two DAC levels. This is the mode I think Chip was mulling over changing its behaviour ...
    evanh wrote: »
    As it is, a high will be whatever you set the 8-bit DAC value to and a low will be $00.
    edited 2018-10-22 02:29
    Oh, no, I might have misunderstood about setting the DAC level in BIT_DAC mode. The %TT doc doesn't say how to set DAC level. I'm now thinking it is done in the one instruction:
    		WRPIN  ##%101xxDDDDDDDD_1x_00000_0, #tpin
    %DDDDDDDD sets the DAC level. 101xx is the usual DAC modes. The _1x_00000_0 tells it to be BIT_DAC operated.
    Look right?
    That seems right.
    edited 2018-10-22 04:00
    evanh wrote: »
    Yes.
    Got it! It sunk in finally. The columns with fixed digits are not in the instruction encodings as individual bits. They're inherent in the mode. Eg: I can see the 1k5 resistor selected in all the DAC comparator modes.
