cog programs separately — Parallax Forums
hi,
dear all,
can we have program cog separately ? i mean if we need run 3 timers simultaneously and get out put how can do it?
other one is can enplane anyone how to run cog separately?
    Yes of course. See COGINIT and COGNEW in the Propeller Manual.
    Depending on what you are trying to do, one cog could run a large number of timers. Different cogs can run the same or different programs.
    For help though, you need to explain precisely what you want to do.
  • Asanka,
    Look at Propeller Education Labs Fundamentals Pg 79 - I think it has the answers for your questions.
  • thanks you so much for ever ,its done.
  • JonnyMacJonnyMac Posts: 9,450
    edited 2018-10-27 15:23
    I had a situation with a commercial laser-tag project where I needed a bunch of timers but had no more cogs left in which to run them. Since timers have to be checked, anyway, I used the delta between checks of the system CNT register. the object is time-oriented, so I also added methods for basic, inline delays. This is just another tool for your bag of tricks. Code attached.
