Writing to SD after removal/reinsert
in Propeller 1
I'm switching a data logger over to C++ (yay!) from spin, but am hitting an odd behavior in the SD card writing bit. I've got a logging switch (on/off) so the user could turn it off, remove the card, insert a new one (or the same really), and turn it back on. I can turn it off/on to my heart's content, but as soon as I remove the card, it's a no go with no further writes occurring. I've simplified it to the program below to demonstrate the issue. I let this run a few loops, then remove the card during the period after the file is closed (and my safe to remove LED is on). Upon reinsertion, no more writes actually happen. Any ideas? Thanks!
#include <stdio.h>
#include <propeller.h>
#include "simpletools.h"
int main(void)
while(1) {
sd_mount(19, 20, 21, 22);
FILE* fp = fopen("test.txt", "a");
fwrite("Testing 123...\n", 1, 15, fp);
fclose(fp);
high(7); // LED for safe to remove ON
print("2 second pause\n");
pause(2000);
low(7); // LED for safe to remove OFF
Not sure it will help any, but do check the return code of sd_mount and see if its throwing any errors.
If this ends up being a feature that isn't supported by Simple + PropGCC, you have a few other alternatives: convert a Spin object to C++ with spin2cpp, use PropWare's SD/FATFS library, use libpropeller's SD/FATFS library
Ah - I'll have a look at making some kind on unmount then and update with the results.
Ray
Ouch. That's too bad
Yes. In fact, PropWare doesn't even need to run anything in a separate cog. If you just want an exact copy of your test program above but all running in a single cog, then try this: (warning: untested)
#include <PropWare/hmi/output/printer.h> #include <PropWare/memory/sd.h> #include <PropWare/filesystem/fat/fatfs.h> #include <PropWare/filesystem/fat/fatfilewriter.h> using PropWare::SD; using PropWare::FatFS; using PropWare::BlockStorage; using PropWare::FatFileWriter; using PropWare::Pin; int main () { const Pin led (Pin::Mask::P7, Pin::Dir::OUT); led.set(); const SD driver; FatFS filesystem(driver); FatFileWriter writer(filesystem, "new2.txt"); while (1) { led.clear(); filesystem.mount(); writer.open(); writer.puts("Testing 123...\n"); writer.close(); filesystem.unmount(); led.set(); pwOut << "2 second pause\n"; waitcnt(CNT + 2*SECOND); } }
But, if you'd like async writes, you'd want something like this (warning: untested)
#include <PropWare/hmi/output/printer.h> #include <PropWare/memory/sd.h> #include <PropWare/filesystem/fat/fatfs.h> #include <PropWare/filesystem/fat/fatfilewriter.h> #include <PropWare/concurrent/runnable.h> #include <PropWare/utility/collection/charqueue.h> using PropWare::SD; using PropWare::FatFS; using PropWare::BlockStorage; using PropWare::FatFileWriter; using PropWare::Runnable; using PropWare::CharQueue; using PropWare::Printer; using PropWare::Pin; class AsyncFileAppender: public Runnable { public: AsyncFileAppender (const char filename[], CharQueue &queue, volatile bool *attemptToMount) : Runnable(this->m_stack), m_led(Pin::Mask::P7), m_filesystem(this->m_driver), m_writer(this->m_filesystem, filename), m_queue(&queue), m_attemptToMount(attemptToMount) { } virtual void run () { PropWare::ErrorCode err; this->m_led.set_dir_out(); while (1) { // Continuously attempt to mount until it succeeds. This should enable crude "auto-mount" on card // insertion do { err = this->m_filesystem.mount(); } while (err); this->m_led.set(); this->m_writer.open(); // Continuously empty the queue, so long as an unmount has not been requested while (*this->m_attemptToMount) while (this->m_queue->size()) this->m_writer.put_char(this->m_queue->dequeue()); // Give it a chance to empty the queue one last time const auto remainingCharacters = this->m_queue->size(); for (size_t i = 0; i < remainingCharacters; ++i) this->m_writer.put_char(this->m_queue->dequeue()); this->m_writer.close(); this->m_filesystem.unmount(); *this->m_attemptToMount = false; this->m_led.clear(); } } private: uint32_t m_stack[256]; // FIXME: Untested stack size. Might need to be bigger... might be way too big const Pin m_led; const SD m_driver; FatFS m_filesystem; FatFileWriter m_writer; CharQueue *m_queue; volatile bool *m_attemptToMount; }; int main () { const char filename[] = "test.txt"; volatile bool attemptToMount = true; char queueBuffer[256]; CharQueue queue(queueBuffer); AsyncFileAppender fileAppender(filename, queue, &attemptToMount); Runnable::invoke(fileAppender); const Printer printer(queue, false); while (1) { printer << "Testing " << 123 << "...\n"; attemptToMount = false; waitcnt(CNT + SECOND * 2); } }
Code size for these two examples is as follows:
Single cog: Code size = 13,952, Total size = 15,328
Multi cog: Code size = Code size = 15,224, Total size = 16,600
The unfortunate thing about this is that PropWare isn't very Windows-friendly. If you're on Windows, I'd recommend libpropeller's SD class. I checked - it has an unmount method and the docs even make explicit mention of freeing up the driver cog.
Could be global, could be static to the function. Probably gets compiled to the same thing?
@geo_leeman, if you prefer to stick with the Simple + PropGCC approach, you probably want to just override the function. If you define your own version of dfs_mount with exactly the same signature, the linker will (should?) select your function instead of the one provided by whatever lib PropGCC has it in. Then of course you can define a dfs_unmount as appropriate and invoke it.
#include <stdio.h> #include <propeller.h> #include "simpletools.h" /* * Library Overrides and Additions for Unmounting */ volatile static int sd_cog; extern uint32_t *_sd_mbox_p; static volatile uint32_t __attribute__((section(".hub"))) sd_mbox[2]; void LoadSDDriver(uint32_t configwords[2]) // Not being called! { print("My LoadSdDriver\n"); use_cog_driver(sd_driver); uint8_t *driver_array = (uint8_t *)get_cog_driver(sd_driver); memcpy(driver_array + 4, configwords, sizeof(uint32_t) * 2); _sd_mbox_p = (uint32_t *)sd_mbox; sd_mbox[0] = 1; sd_cog = cognew(driver_array, (uint32_t *)sd_mbox); while (sd_mbox[0]); } void remove_driver(int i) { print("My remove_driver\n"); _driverlist[i] = NULL; } static int sd_driver_idx; extern _Driver _FileDriver; extern _Driver _SimpleSerialDriver; const int DRIVER_LIST_SIZE = 16; _Driver *_driverlist[] = { &_SimpleSerialDriver, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL }; int add_driver(_Driver *driverAddr) { print("My add_driver\n"); int i; for(i = 0; i < DRIVER_LIST_SIZE; i++) { if(_driverlist[i] == 0) break; } //print("i = %d", i); //print("\n"); _driverlist[i] = driverAddr; return i; } int sd_mount(int doPin, int clkPin, int diPin, int csPin) { print("My sd_mount\n"); _SD_Params* mountParams = (_SD_Params*)-1; static _SD_SingleSPI sdPins; sdPins.MISO = doPin; sdPins.CLK = clkPin; sdPins.MOSI = diPin; sdPins.CS = csPin; static _SD_Params params; params.AttachmentType = _SDA_SingleSPI; params.pins.SingleSPI = sdPins; mountParams = ¶ms; if (mountParams == (_SD_Params*)-1) { return -1; } uint32_t mountErr = dfs_mount(mountParams); if (mountErr) { //print("Mount error: %d\n", mountErr); return mountErr; } // print("done.\n\n"); add_driver(&_FileDriver); return 0; } extern int dfs_mountflag; void dfs_unmount(void) { print("My dfs_unmount\n"); dfs_mountflag = 0; print("%d", sd_cog); cogstop(1); } void sd_unmount(void) { print("My sd_unmount\n"); dfs_unmount(); // Will shut down cog remove_driver(sd_driver_idx); } /* * Main */ int main(void) { while(1) { sd_mount(19, 20, 21, 22); // Leeman Geophysical Logger // sd_mount(12, 13, 11, 8); // ASC+ Board FILE* fp = fopen("test.txt", "a"); fwrite("Testing 123...\n", 1, 15, fp); fclose(fp); high(7); // LED for safe to remove ON print("2 second pause\n"); pause(2000); low(7); // LED for safe to remove OFF sd_unmount(); } }
