Splitting gerber files in two, but how-to ?
I'd like to have some PCBs fabruicated, the thing is that they are a bit larger than the cheapest at 10x10 cm. I could partition the project in two and keep two schematics and pcbs or do one and just "split" the gerbers and drill file. Of course I have to provide for ways of connecting both pcbs together but keeping one schematic/pcb seems simpler.
Which tools/tool would do the job ?
Do you have a finished PCB, gerber plotted, you need to somehow slice ? 'Splitting gerber files in two' ?
Or do you mean you have not started yet, and want to have one SCH map to two PCB's in one CAD file ?
It's probably much easier either take a bit more time and pack it in, or just to pay a bit more for the panel it needs to be.
That said, you can take one SCH to create 2 sub-panels, that's often done for complicated right angle, or display/kbd type mechanical solutions.
could you please elaborate on that ? (my target shematic capture/pcb design is KiCad)
It is not that all components wouldn't fit in 10x10, it is that I need it to be larger because it is mostly a keyboard, asymmetric, if not I'd just use two equal halves.
Works in almost any CAD pgm : you just create courtyards for each area, and where you intend to join them, via the cables, you have a choice of running rats nests, or using some layers NOT in the final designs.
Where the CAD tools can report # unrouted, I usually put in some text in the tram lines, to remind me if editing later.
So, can you make two copies of the PCB file and move the board outlines around so that one covers one half and the other covers the other half.
Now create gerbers from those two board files.
Assuming your PCB company does not reject such a mangled arrangement of outlines.
Probably you can take the final pcb design, mark the sub-pcbs on a new layer, and then copy the whole pcb file multiple times. Now take each copy in turn, and delete all outside of the section you require, and then make gerbers for the required section.
Good point. When you "save" gerber with GCPowerplace, it is actually recreating the gerber based upon your edits so it still conforms to the gerber standard.
