How to get more current out of a Propeller Asc+ pin?
Hello--
I am using a Propeller ASC+ with a relay that is activated when it receives 30mA. Looking at the specs for the ASC+, it says that it should sink/send approximately 40mA. I am measuring the current output of pin 9 on the board at 1.4mA.
Is this a glitch on my board? Is there a way to increase the output of amps so I can still use this relay?
The specs for the relay can be found here.
Any thoughts or suggestions would be greatly appreciated!
What voltage is the relay ?
30mA is too much to expect from a typical MCU pin, and if you look at the ASC notes here , that shows a 2.2k series R, for '5V tolerance'
(3v3/2.2k is your 1.5mA)
That means you cannot drive any relay directly, but any small N-CH mosfet, or digital transistor, would be able to provide the 30mA needed, with low drop across the switch.
A catch diode across the relay is likely to be also needed.
Please let me know if this changes your thoughts on your suggested solutions. Thank you!!
However a simple NPN (2N2222) etc with a base resistor of around 1k to 3k3 would do nicely and then the collector could drive the relay and of course add a small 1N4148 diode across the coil (cathode to 5V).
https://www.electronics-tutorials.ws/blog/relay-switch-circuit.html
In practice the 10k "bias" resistor is never really needed for logic switching circuits as the logic drive is high or low and even if it were floating the npn can't turn on anyway. There are circuits that might need a bias/pulldown resistor but most do not.
The a bipolar transistor being driven by a PWM signal you'd use a strong pulldown on the base for faster switching.
Thank you for your help. We took the transistor idea and ran with it, but still had the same issue. We then attempted to run down where the current was going (because it is clear we are losing it somewhere).
We ended up with the propeller board by itself with one wire connected to ground and another connected to an I/O pin that was programmed to send a signal every 5 seconds (we tested pin 8, 9, and 2). Measuring the voltage we got 3.3V, measuring the amps we got 0.2mA.
Is this a glitch in my board (we tried it with two of my boards). The specs indicate that it should be 1.4--right? Did I blow my board somehow and everything else is working?
I will also add that this exact same set up (the shield, transistor, etc.) works if we connect it to an Arduino board. I would really like to use the propeller board for various data collection reasons....I mention it because I wonder if there is some fundamental difference in the amount of amps that can pass through the Arduino vs. the propeller.
Any thoughts? Does anyone else's board give them these measures? Thank you!
If you are using an NPN then it will amplify the current going into it's base, but more correctly in this kind of circuit we just want it to turn fully on like a switch so we supply more than enough and more again base current. Rough "rule-of-thumb" is that while you operate the transistor well within its specs that the current gain is around 100, so if we supply 2.5ma to the base/emitter then we would be able to switch up to 250ma. You can't force 250ma into a load when it only draws 30ma at 5V so therefore the transistor can be viewed as a sensitive switch.
@"frank freedman" - Please do not mention those big and ugly TIP devices, because that's where they belong!
@Mark_T - When you are driving the transistor from push-pull outputs such as the Prop's I/O then an iddly piddly little 10k resistor doesn't compare to the base being pulled down through a 1k resistor, does it? What irks me is that a lot of circuits are copied from one application and technology to a different application and technology without thinking about what is and what is not needed. The pulldown is useful when being driven at a higher frequency from voltage sources but CMOS of course does its own "pulling down". The other reason for a base/emitter resistor is to act as a voltage divider so that the transistor needs a higher voltage to turn on but that is rarely the case in most circuits.
How exactly did you drive the Prop pins - 0.2mA is not expected (unless you have 13.5k of total series Base R) , but did you enable CMOS output drive ?
0.2mA base drive is likely to be light into a generic NPN device with 30mA load, better to target ~ 1mA
The Ardunio is usually 5V, whilst Prop is 3v3, so you will have slightly less (~ -40%) base drive in a 3v3 system, other items being equal.
