I2C communication with "C" language
in Propeller 1
Hi
I want to do my own cnc level controller using the mpu-6050 with "C'' language, I tried most i2c device communicate 'c' program but not work. does have anybody Test code i2c "C" language for P8x32A?
somebody help me?
is there some library?
somebody help me?
mpu6050 i add the wait while busy ampu6050 i add the wait while busy and it never jumps out of the loop since i isue the fitst commandnd it never jumps out of the loop since i isue the fitst comm[img][/img]and(Attached file)
this my programs,
#include "simpletools.h" // Include simpletools header
// MPU6050 Slave Device Address
const uint8_t MPU6050SlaveAddress = 0x68;
// sensitivity scale factor respective to full scale setting provided in datasheet
const uint16_t AccelScaleFactor = 16384;
const uint16_t GyroScaleFactor = 131;
// MPU6050 few configuration register addresses
const uint8_t MPU6050_REGISTER_SMPLRT_DIV = 0x19;
const uint8_t MPU6050_REGISTER_USER_CTRL = 0x6A;
const uint8_t MPU6050_REGISTER_PWR_MGMT_1 = 0x6B;
const uint8_t MPU6050_REGISTER_PWR_MGMT_2 = 0x6C;
const uint8_t MPU6050_REGISTER_CONFIG = 0x1A;
const uint8_t MPU6050_REGISTER_GYRO_CONFIG = 0x1B;
const uint8_t MPU6050_REGISTER_ACCEL_CONFIG = 0x1C;
const uint8_t MPU6050_REGISTER_FIFO_EN = 0x23;
const uint8_t MPU6050_REGISTER_INT_ENABLE = 0x38;
const uint8_t MPU6050_REGISTER_ACCEL_XOUT_H = 0x3B;
const uint8_t MPU6050_REGISTER_SIGNAL_PATH_RESET = 0x68;
void MPU6050_Init();
void Read_RawValue(uint8_t deviceAddress,uint8_t regAddress);
void I2C_Write(uint8_t deviceAddress,uint8_t regAddress,char *data);
i2c *eeBus; // I2C bus ID
char testStr[] = {0, 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0};
int16_t AccelX, AccelY, AccelZ, Temperature, GyroX, GyroY, GyroZ;
double Ax, Ay, Az, T, Gx, Gy, Gz;
int main() // Main function
eeBus = i2c_newbus(16,15, 1); // Set up I2C bus, get bus ID;
//I2C_Write(0x68,0x6b,0);
//print("done");
MPU6050_Init();
while (1){
Read_RawValue(MPU6050SlaveAddress, MPU6050_REGISTER_ACCEL_XOUT_H);
//print("testStr = %s \n", testStr); // Display result
print("Ax: %f",Ax);
print(" Ay: %f",Ay);
print(" Az: %f",Az);
print(" T: %f",T);
print(" Gx: %f",Gx);
print(" Gy: %f",Gy);
print(" Gz: %f",Gz);
print(" \n ");
pause(1000);
void I2C_Write(uint8_t deviceAddress,uint8_t regAddress,char *data){
i2c_out(eeBus, deviceAddress,regAddress, 1, data, 1);
while(i2c_busy(eeBus,deviceAddress));
void Read_RawValue(uint8_t deviceAddress,uint8_t regAddress){
i2c_in(eeBus, deviceAddress,regAddress, 1, testStr, 14);
AccelX = (((int16_t)testStr[1]<<8) | testStr[2]);
AccelY = (((int16_t)testStr[3]<<8) | testStr[4]);
AccelZ = (((int16_t)testStr[5]<<8) | testStr[6]);
Temperature = (((int16_t)testStr[7]<<8) | testStr[8]);
GyroX = (((int16_t)testStr[9]<<8) | testStr[10]);
GyroY = (((int16_t)testStr[11]<<8) | testStr[12]);
GyroZ = (((int16_t)testStr[13]<<8) | testStr[14]);
//divide each with their sensitivity scale factor
Ax = (double)AccelX/AccelScaleFactor;
Ay = (double)AccelY/AccelScaleFactor;
Az = (double)AccelZ/AccelScaleFactor;
T = (double)Temperature/340+36.53; //temperature formula
Gx = (double)GyroX/GyroScaleFactor;
Gy = (double)GyroY/GyroScaleFactor;
Gz = (double)GyroZ/GyroScaleFactor;
void MPU6050_Init(){
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_SMPLRT_DIV,(char*) 7);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_PWR_MGMT_1,(char*) 1);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_PWR_MGMT_2,(char*) 0);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_CONFIG,(char*) 0);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_GYRO_CONFIG,(char*) 0);//set +/-250 degree/second full scale
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_ACCEL_CONFIG,(char*) 0);// set +/- 2g full scale
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_FIFO_EN,(char*) 0);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_INT_ENABLE,(char*) 1);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_SIGNAL_PATH_RESET,(char*) 0);
I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_USER_CTRL,(char*) 0);
BTW, if you post code make sure you apply the code tags (edit icons - B I U S C etc ) so you don't lose any formatting or whitespace to it like this:
#include "simpletools.h" // Include simpletools header // MPU6050 Slave Device Address const uint8_t MPU6050SlaveAddress = 0x68; // sensitivity scale factor respective to full scale setting provided in datasheet const uint16_t AccelScaleFactor = 16384; const uint16_t GyroScaleFactor = 131; // MPU6050 few configuration register addresses const uint8_t MPU6050_REGISTER_SMPLRT_DIV = 0x19; const uint8_t MPU6050_REGISTER_USER_CTRL = 0x6A; const uint8_t MPU6050_REGISTER_PWR_MGMT_1 = 0x6B; const uint8_t MPU6050_REGISTER_PWR_MGMT_2 = 0x6C; const uint8_t MPU6050_REGISTER_CONFIG = 0x1A; const uint8_t MPU6050_REGISTER_GYRO_CONFIG = 0x1B; const uint8_t MPU6050_REGISTER_ACCEL_CONFIG = 0x1C; const uint8_t MPU6050_REGISTER_FIFO_EN = 0x23; const uint8_t MPU6050_REGISTER_INT_ENABLE = 0x38; const uint8_t MPU6050_REGISTER_ACCEL_XOUT_H = 0x3B; const uint8_t MPU6050_REGISTER_SIGNAL_PATH_RESET = 0x68; void MPU6050_Init(); void Read_RawValue(uint8_t deviceAddress,uint8_t regAddress); void I2C_Write(uint8_t deviceAddress,uint8_t regAddress,char *data); i2c *eeBus; // I2C bus ID char testStr[] = {0, 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0}; int16_t AccelX, AccelY, AccelZ, Temperature, GyroX, GyroY, GyroZ; double Ax, Ay, Az, T, Gx, Gy, Gz; int main() // Main function { eeBus = i2c_newbus(16,15, 1); // Set up I2C bus, get bus ID; //I2C_Write(0x68,0x6b,0); //print("done"); MPU6050_Init(); while (1){ Read_RawValue(MPU6050SlaveAddress, MPU6050_REGISTER_ACCEL_XOUT_H); //print("testStr = %s \n", testStr); // Display result print("Ax: %f",Ax); print(" Ay: %f",Ay); print(" Az: %f",Az); print(" T: %f",T); print(" Gx: %f",Gx); print(" Gy: %f",Gy); print(" Gz: %f",Gz); print(" \n "); pause(1000); } } void I2C_Write(uint8_t deviceAddress,uint8_t regAddress,char *data){ i2c_out(eeBus, deviceAddress,regAddress, 1, data, 1); while(i2c_busy(eeBus,deviceAddress)); } void Read_RawValue(uint8_t deviceAddress,uint8_t regAddress){ i2c_in(eeBus, deviceAddress,regAddress, 1, testStr, 14); AccelX = (((int16_t)testStr[1]<<8) | testStr[2]); AccelY = (((int16_t)testStr[3]<<8) | testStr[4]); AccelZ = (((int16_t)testStr[5]<<8) | testStr[6]); Temperature = (((int16_t)testStr[7]<<8) | testStr[8]); GyroX = (((int16_t)testStr[9]<<8) | testStr[10]); GyroY = (((int16_t)testStr[11]<<8) | testStr[12]); GyroZ = (((int16_t)testStr[13]<<8) | testStr[14]); //divide each with their sensitivity scale factor Ax = (double)AccelX/AccelScaleFactor; Ay = (double)AccelY/AccelScaleFactor; Az = (double)AccelZ/AccelScaleFactor; T = (double)Temperature/340+36.53; //temperature formula Gx = (double)GyroX/GyroScaleFactor; Gy = (double)GyroY/GyroScaleFactor; Gz = (double)GyroZ/GyroScaleFactor; } void MPU6050_Init(){ I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_SMPLRT_DIV,(char*) 7); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_PWR_MGMT_1,(char*) 1); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_PWR_MGMT_2,(char*) 0); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_CONFIG,(char*) 0); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_GYRO_CONFIG,(char*) 0);//set +/-250 degree/second full scale I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_ACCEL_CONFIG,(char*) 0);// set +/- 2g full scale I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_FIFO_EN,(char*) 0); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_INT_ENABLE,(char*) 1); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_SIGNAL_PATH_RESET,(char*) 0); I2C_Write(MPU6050SlaveAddress, MPU6050_REGISTER_USER_CTRL,(char*) 0); }
