Flip Electrical Question
Beavis3215
in Propeller 1
If I have a Propeller Flip project that runs on an external LIPO battery, can I use Simple-IDE terminal at the same time, without the LIPO power and the USB power conflicting. In other words, the flip is running on the LIPO, and the flip is connected to the PC at the same time.
Short answer is Yes. From the Flip Guide:
3.3-volt Output
The 3.3V▷ output draws power from the 3.3 volt supply, which draws power from both
the USB port and the ▷5-9V input. The total available current is limited by the power
source.
USB Power
When connected via a USB port, the Propeller FLiP module will request 500 mA of 5-volt
power from a computer or hub or 1,500 mA from a USB charger. If the request is
granted, the module will use the power from the USB port, to power both the 3.3 V
supply and the USB 5V▷ output.
If the request is denied, the Propeller FLiP module will light the yellow Fault LED, to
indicate that it is unable to draw power from the USB port. The module will still be able
to communicate and accept a program over a computer or hub’s USB port, but it will
require external power at the ▷5-9V input to operate.
