AEM40940 – Energy Harvesting Power Management IC
in Propeller 1
Anybody have experience running a prop with one of these https://e-peas.com/products/energy-harvesting/rf/aem10940-2/.
Looking for input on how efficient it is and distance it has to be from wireless source to be of any use. Does it have to be within 10 feet of Wi-Fi hub etc..
0.1 / (4 pi 10^2) = 80 microwatts per m^2. That's about -11 dBm, compared to the stated -17dBm limit of the aem10940 device. Still, even if it can extract 80 microwatts, that amount of power is potentially only enough to operate a Prop 1 in RCslow (3 volts * 5 microamps = 15 microwatts).
There was company at the Sensors Expo in San Jose last month that had an impressive demo running a bright LED on harvested RF. The LED and a couple of other parts was mounted on a board about 12cm longish if I remember correctly.
https://www.theepochtimes.com/powercast-2018-sensors-expo-and-conference_2577722.html
http://www.powercastco.com/
Sure you can move energy around using RF. That is what radios do.
As Tracy points out the energy available becomes very small very rapidly with distance.
The antenna is as important as any high efficiency chip connected to it.
I notice the demo at the sensors expo is a 12cm or so antenna in very close range to the transmitter. Kind of a party trick.
@Tracy, Did you say 80 microwatts per m^2 ?
I'd love to see a Propeller powered from a WiFi router 10 meters away. Even with a 1 meter square antenna array !
on an RF spectrum analyzer readily if any old bit of wire is coupled to its input.
