Over voltage damage to pin through voltmeter?
If I connect a voltmeter between a 12v power supply and a propeller pin set to logic low, will it damage the pin? The propeller and power supply share the same ground.
Just to be safe you might want to put a 10 K-ohm resister in series with your voltmeter test leads to ensure that you don't run too high of a voltage/current to the Prop pin. Or better yet, just measure the pin voltage from ground. I would also wait to hear from some of the hardware gurus on the forum just to be sure.
You say voltmeter, but if it is a multimeter, be sure by no mistake is it left on a current measuring range when you make that hookup to 12V! Sure smoke!
While on this subject, there is a potential issue with ohms, continuity and diode-check measurements. Multimeters vary quite a bit in the voltage that they put behind those measurements. For example, I never use my fancy Agilent 6.5 digit 34401A multimeter for troubleshooting Prop boards for continuity, because on all its ohms and continuity ranges it puts out more than 7 volts behind the measurement, at up to 100 microamps current. While the substrate diodes on the Prop (and most ICs) can absorb that kind of current, it can be a disaster when a Prop circuit is unpowered or is running on RCslow. Even 100 µA can overflow the power supply and subject the entire circuit to damaging voltage. For that kind of troubleshooting, I reach for an old Beckman Tech-300 that uses less than 0.4V for its ohms measurements, which is safe, and it has the added advantage that it does not forward bias diodes (except on its diode test range), which is an advantage for troubleshooting. Even a cheap Chinese import multimeter I have (labeled "Excel"). keeps the potential on its ohms ranges at under 3 volts. It is definitely something to be aware of. It's no joy to have a circuit ruined by the test instrument.
significant currents to flow briefly.
One would hope though that the meter is basically has > 1M resistor is series with anything internal,
so only the stray inductance and capacitance of the leads could cause issues.
https://www.eevblog.com/forum/beginners/multimeter-input-protection-what-are-these-bjts-doing/
Those should be 'on the other side' of the main series divider resistor, so they may change the apparent resistance, but should not jump from uA to mA.
Most multimeters have 1~10M input dividers, but some better ones remove the down side resistor on the lowest range, to go > 100M, and some have an optional lower load
The most likely oops, is 'range-right, but probes in wrong place' - which everyone denies ever doing...
