Unintentional ASCII char actor showing up on Adafruit serial lcd
I've got a project using the Serial LCD
https://www.adafruit.com/product/499
Everything is working pretty well except that when I use the LCD.CLS command I get an ascii character that correlates to the last command in hex from the cls routine.
has anyone else ran into it and what's the fix?
What Parallax product are you trying to use this with? Can you post the code?
using this
SparkFun Serial LCD driver.spin
here's the first statement and the "X" appears as soon as the CLS command is given
LCD.init(TX_PIN, BAUD, 4, 20) 'Sets buad rate and pin for Adafruit Serial back pack display
LCD.cls
wait_ms(100)
lcd.str(string("Core_5_AD_seccnt_2_roundrobin_rc_2")) 'Splash SCREEN_ST
of course there is a bunch more code but I used a long pause between statements to watch when the "x" appears and it's there as soon as I use the cls command
===Jac
With
https://www.adafruit.com/product/781
Your right, I was too close to the problem when I wrote the post.
