simpletools code to C conversion, can't figure it out.
Beavis3215
I have some code examples for using DIRA, OUTA and waitpeq, but nothing as simple as the C equivalent of on_sensor = input(19) or if (on_sensor == 1).
Here is what I mean
This Works
This is what Im trying to do
Just tying to understand the inputs for now. It seems like I should be pretty close.
Is there somewhere in help that talks about this?
Here is what I mean
void button_time();
static volatile int delay; // delay is global
int main() // Main function
cog_run(button_time,128); // Push button control runs in other cog
set_directions(17,16,11);
int on_sensor;
int off_sensor;
while(1)
on_sensor = input(19);
off_sensor = input(18);
if (on_sensor == 1)
set_output(17,1); // Turn magnet on
if (off_sensor == 1)
pause(delay); // Delay is assigned in button_time
set_output(17,0); // Turn magnet off
set_output(16,1); // Timing light on
pause(5);
set_output(16,0); // Timing light off
This Works
void button_time();
int on_sensor = 1 << 19;
int off_sensor = 1 << 18;
DIRA &= ~(1 << 19);
DIRA &= ~(1 << 18);
while(1)
off_sensor= input(18);
if (on_sensor == on_sensor)
if (off_sensor == off_sensor)
pause(5);
(edited to correct syntax)
int get_pin(int pinNum) { return (INA >> pinNum) & 1; }This doesn't change the direction of the IO pin which can be useful when using it to monitor the output state controlled by other processes.int input(int pin) // input function definition { int mask = 1 << pin; // Set up mask DIRA &= ~mask; // AND DIRA with NOT mask return (INA & mask) >> pin; // Return input state }It returns the value of the pin. Note that it also forces the pin to be input only.Awesome as always
void button_time() { //set_directions(13,8,0b111111); int lights = 0b111111 << 14; //Timing delay in binary on LED's DIRA |= (lights); int t = 20; //int advance; //int retard; int advance = 1 << 15; int retard = 1 << 14; while(1) { if ((INA & retard) == retard) // If retard button high { t = t + 1; if (t > 64) // Don't allow t to exceed 64 { t = 64; } } if ((INA & advance) == advance) // If advance button high { t = t - 1; if (t < 1) // Keep t 0 or larger { t = 1; } } delay = t; // Pass delay to main function //set_outputs(13,8,t); // Put t value on output lights OUTA |= (t << 14); pause(300); } }The simpletools code is remarked out as to be non operational. I am attempting to replace the simpletools code with C code, but I am making a mistake. I don't quite get it, any Ideas?
Dave, I also tried to find in simple libraries the C code conversions of simple code, but I can't find it. Can you get me the path through Simple IDE help to get to them?
But any other cog can make the pin an output, right?
To set the direction of the 6 bits to outputs you should do You can find the location of the library code by clicking on Tools and then Properties. Or you can just hit the F6 key. Look for "Library Folder" to find the location. The source for the pin I/O routines is located in the Utility/libsimpletools/source folder.
@Rayman, you are correct. Any other cog can make the pin an output.
