Simple C Coding Question
in Propeller 1
Hello,
I am trying to get the following code to print d = f.
f is a 2x1 vector equal to [10,5]'. However, when I print d it just gives me [0,0]'. d should be the same as f. What am I doing wrong in that last line of code?
David
float phi = 0;
float theta = 0;
float gx = 10;
float gy = 5;
float gz = 1;
float f[2][1] = {
{gx+gy*sin(phi)*tan(theta)+gz*cos(phi)*tan(theta)},
{gy*cos(phi)-gz*sin(phi)}
float d[2][1] = {f[2][1]};
David
float d[2][1] = {f[2][1]};is not doing what you think it does. "f[2][1]" is a specific element of "f", not the whole array. So you are creating a two element array and initializing it with only one element.
Worse, it is an undefined element. F was declared as
float f[2][1] = {...};so the only legal references to f are "f[0][0]" and "f[1][0]", so "f[2][1]" is undefined.Thank you for your reply. Now I understand why it's not working but I'm still not sure how to fix it. The reason I want to do this is so I can multiply the array by a scalar value. So what I want to be able to do is something like this:
float d[2][1] = .001 * {f[2][1]};Thanks,
David
C doesn't work that way -- it does not allow multiplication of an array by a scalar (I think Fortran does, but C doesn't). You'll have to do it at run time in a loop, something like:
int i; ... for (i = 0; i < 2; i++) { d[i][0] = .001 * f[i][0]; }Which also raises an interesting point; why did you declare the arrays as two dimensional (like f[2][1]) when the second dimension only has one possible value? It would be simpler to write just f[2]:float f[2] = { ... } float d[2]; int i; ... for (i = 0; i < 2; i++) { d[i] = .001 * f[i]; }Eric
I just wanted to thank you for your help. Your response got me going to the next step in my coding project. I am trying to implement an extended Kalman filter to estimate roll and pitch. Once I hopefully get it working I will post the code on the forums to give back.
David
