SD Card wont 'click' into place on my ASC+ board
                    Hello--
Playing with the board and something happened and now my SD Card wont 'click' into place on my ASC+ board. It will insert, but won't stay in place. I should note that this same card WILL stay in place on a different board, so I know its the board, not the card.
Has anyone encountered this issue? Is there a fix? This seems like a really silly thing to render an expensive board useless (or at least unable to collect data).
Thank you!
Thank you!
Parallax is not the manufacturer. They sold it on their site.
As you stated, 1mgh.com was the manufacturer. Maybe Martin will chime in.
Those little metal tabs have a way of bending. They can be persuaded back into place with care.
"Playing" is probably what broke it, so it's a simple mechanical failure probably caused by some stress induced perhaps by trying to remove the card by force. If we went to the forum everytime something broke it would not only be a waste of everyone's time since it's our own responsibility, but it would probably drown out the forum.
However, you could (and I would) just use a piece of tape to hold the card in or remove the spring mechanism in the connector itself so that it doesn't try to eject the card. Ugly perhaps, but we've all been down that road, accepted the loss, and it tends to make us take a little more care in the future.
I hand test each ASC+ that I send out myself. That includes inserting and removing a uSD card about a dozen times into each board. But the push-in/push-out latching mechanism is tiny and delicate. Amphenol no longer manufactures these particular ones but I do have a small stock of them left.
