Learning C - Attached file do not compile
in Propeller 1
I am trying to learn C.I have done very little programing.I am trying to put two files together.
Polite Activity bot and Sony IF roaming Activity bot.
I came up with the attached file and It does not compile.I need some help.
Thanks.
Siri
Thanks.
Siri
wav play("excuseme.wav"); // play wav file excuse mewhich should have an underscore between wav and play as follows:
wav_play("excuseme.wav"); // play wav file excuse mesee https://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-devices/play-wav-files
In spite not giving the error details, you spotted the isses.
Thank you.
Siri
