Spurius characters occationally
in Propeller 1
The weather program that I've been working on for a while is nearing completion, thanks to a lot of help from this forum!
Sometimes weird characters show up after running it. If left for hours it also sometimes locks up. I don't know how to figure this out. There must be some anomaly somewhere.
How do I check for this?
There are also a few other things that need completing.
It's a long program, but if anyone has time on their hands and could point me to some bad code, that would be appreciated?
OBJ
vga: "VGACOLOR_320x240_CURSOR" ' VGA Driver need 2 Cog's
i2c : "I2C pasm driver v1.8od"
PUB main
cognew(windSpeed,@stack)
cognew(RTCcog,@Rtcstack)
init
initScreen
ms := 0
repeat
dira[16]~~
Winput:=I2C.readByte(MCP,GPIOA) ' wind direction
dir:=winput
updateDir
waitcnt((clkfreq / 1000) * 1 + cnt) ' wait 1 ms
'get_measurements '' reads temperature and pressure into UT and UP
I2C.writeByte(BMP,CONTROL,TEMP) ' start a temperature measurement
waitcnt(cnt + clkfreq / 10000 * 45) ' wait 4.5ms
UT := I2C.readWordB(BMP,ADC) ' read temperature
I2C.writeByte(BMP,CONTROL,PRESSURE) ' start a pressure measurement - 0 oversampling
UP := I2C.readWordB(BMP,ADC) ' read pressure
convert_measurements
PSI:=(p-1280)/(32)
updateSpeed
waitcnt(clkfreq/2+cnt)
ms++
str(15,27, $0F, $00,string("reset at 0"))
decxy(27, 27, $08, $00, (120 - ms))
if ms=>120 'works out to be every 71 seconds
ms := 0 'clear and restart counter
gust := 0 'clear gusts
updatetime
if (ms==40) OR (ms==80) OR (ms==2)
updateTemp
updateBarom
updateHDC
outa[16]~~
waitcnt(clkfreq + cnt) 'adds a second to the ms countdown
outa[16]~
PRI updateSpeed '
'decxy(11, 3, $08, $00, speed)
updategusts
updateMax
PRI updateGusts
if speed > gust
gust:= speed
if ms==120
gust:=0
decxy(29,3,$0B,$00,gust)
PRI updateMax
if speed > maxWind
maxWind := speed
decxy(11,5,$0B,$00,maxWind)
hex(timbuf[2],2)
str(19, 5, $0B, $00,@nstr)
str(21, 5, $0B, $00, string(":"))
hex(timbuf[1],2)
str(22, 5, $0B, $00,@nstr)
PRI updateTime 'this is time in lower right corner
hex(timbuf[2],2) 'convert hours to string stored at nstr
str(31, 25, $0B, $00,@nstr)
str(33, 25, $0B, $00, string(":"))
hex(timbuf[1],2)
str(34, 25, $0B, $00,@nstr)
str(36, 25, $0B, $00, string(":"))
hex(timbuf[0],2)
str(37, 25, $0B, $00,@nstr)
PRI updateTemp 'this is inside temp from baro sensor
decxy(10, 9, $0A, $00, (T * 9 / 5 + 320)/(10)) ' Print farenheit
str(13,9,$0A,$00,string("F"))
PRI updateBarom
decxy(23, 9, $0B, $00,PSI)
str(28,9,$0E,$00,string("2 decimals"))
PRI updateHDC | local_long
local_long := HDC << 1 | 1
I2C.command(HDC,$00) 'start a temp, hum measurement
waitcnt(clkfreq/10+cnt)
I2C.arbitrary(@local_long,1,@local_long,4)
temp_C := local_long.byte[0] << 8 | local_long.byte[1]
temp_C := temp_C * 165 / 65536 - 40
Far := temp_C * 9/5+32
decxy(10,11,$0A,$00,Far) 'this is outside temp
str(13,11,$0A,$00,string("F"))
RH := local_long.byte[2] << 8 | local_long.byte[3]
RH := RH * 100 / 65536
str(10,14,$0F,$00,string("RH"))
decxy(13,14,$0A,$00,RH)
str(15,14,$0A,$00,string("%"))
DP := Far - ((100-RH)/5)
str(17,14,$0F,$00,string("DP"))
decxy(20,14,$0A,$00,DP)
str(23,14,$0A,$00,string("F"))
PRI updateDir
binxy(8, 16, $0E, $00, Winput, 8) ' Print binary Winput cyan on black
case Winput
%0000_0110: '128
updateNeedle(@wind_N)
str(12, 7, $0D, $00,string("N "))
%0000_0100: '129
updateNeedle(@wind_NNE)
str(12, 7, $0D, $00,string( "N NE"))
%0000_1100: '1
updateNeedle(@wind_NE)
str(12, 7, $0D, $00,string("NE "))
PRI updateNeedle(ptr) | x, y
repeat y from 19 to 25
repeat x from 2 to 8
printxy(x, y, $0D, $00, byte[ptr++]) ' Print Needle white on black
PRI init | i, j, k, p1, offs
''* Start VGA Cog's, Clear Screen and *
''* set Cursor's *
I2C.start(scl,sda,bitrate)
offs := 62 ' 62 Bytes BMP-Header not used, 128x128 2 Color Bitmap
repeat i from 15 to 0
repeat j from 7 to 0
p1 := (i * 16) + (j * 256)
repeat k from 0 to 15
fontbuff[p1+k] := reverse(font[offs++])
wordfill(@vgabuff, $0F20, 1200) ' Clear Screen with $20 (Space) FG-Color $F (white), BG-Color $0 (black)
vga.start(video, @vgabuff, @fontbuff, @cursor, @sync) ' Start Video Driver
waitcnt(clkfreq * 1 + cnt) ' wait 1 second for cogs to start
I2C.writeWordB(HDC,Config_reg,Config_params) 'configure HDC
str(0, 16, $0F, $00, @strWinput) ' Print "Winput" white on black
PRI reverse(val) : new | i
''* Reverse a Byte *
''* eg. %01000000 = $40 to %00000010 = $02 *
i := 1
val <<= 32 - 8
repeat 8
if ((val <-= 1) & 1) == 1
new += i
i *= 2
PRI getPos(x, y)
return (x + y * 40) * 2
PRI print(fgc, bgc, char)
''* Print Character char at current pos *
''* with Foreground-Color fgc and *
''* Background-Color bgc *
vgabuff[pos++] := char
vgabuff[pos++] := bgc * 16 + fgc
PRI printxy(x, y, fgc, bgc, char)
pos := getPos(x, y)
PRI str(x, y, fgc, bgc, string_ptr)
''* Print String at x, y *
pos := (x + y * 40) * 2
repeat strsize(string_ptr)
print(fgc, bgc, byte[string_ptr++])
PRI drawBox(x, y, w, h, fgc, bgc) | t1, m, b, i
''* Draw Box at x, y with w = width, h = height *
''* Foreground.Color fgc *
t1 := (y * 40 + x) * 2
m := t1 + 80
b := m + ((h-2) * 80)
pos := t1
print(fgc, bgc, $80)
fill(fgc, bgc, $81, w-2)
print(fgc, bgc, $82)
repeat i from 0 to h-3
pos := m + i * 80
print(fgc, bgc, $86)
fill(fgc, bgc, $20, w-2)
pos := b
print(fgc, bgc, $83)
print(fgc, bgc, $84)
PRI fill(fgc, bgc, char, len) | x
''* Fill len of Char's with char *
''* at current pos *
if len <> 0
repeat x from 1 to len
PRI decxy(x, y, fg, bg, val)
pos := getPos(x, y)
prn(fg, bg, val)
print(fg, bg, $20)
PRI prn(fg, bg, val) | dig
dig := 48 + (val // 10)
val := val/10
if val > 0
prn(fg, bg, val)
print(fg, bg, dig)
PRI binxy(x, y, fgc, bgc, value, digits)
''* Print binary value at x, y *
value <<= 32 - digits
repeat digits
print(fgc, bgc, (value <-= 1) & 1 + "0")
PUB convert_measurements | X1, X2, X3, B3, B4, B5, B6, B7, oss
' converts uncalibrated UT and UP into calibrated temperature T and pressure P
X1 := ((UT - AC6) * AC5) ~> 15 ' X1 := (UT - AC6) * AC5 / 2^15
X2 := ~~MC << 11 / (X1 + ~~MD) ' X2 := MC * 2^11 / (X1 + MD)
B5 := X1 + X2 ' B5 := X1 + X2
T := (B5 + 8) ~> 4 ' T := (B5 + 8) / 2^4
oss := 0
B6 := B5 - 4000 ' B6 := B5 - 4000
X1 := (B2 * ((B6 * B6) ~> 12)) ~> 11 ' X1 := (B2 * (B6 * B6 / 2^12)) / 2^11
X2 := (~~AC2 * B6) ~> 11 ' X2 := AC2 * B6 / 2^11
X3 := X1 + X2 ' X3 := X1 + X2
B3 := (AC1 * 4 + X3) ~> 2 '* ' B3 := ((AC1 * 4 + X3) << oss + 2) / 4
X1 := (~~AC3 * B6) ~> 13 ' X1 := AC3 * B6 / 2^13
X2 := (B1 * ((B6 * B6) ~> 12)) ~> 16 ' X2 := (B1 * (B6 * B6 / 2^12)) / 2^16
X3 := ((X1 + X2) + 2) ~> 2 ' X3 := ((X1 + X2) + 2) / 2^2
B4 := (AC4 * (X3 + 32768)) ~> 15 ' B4 := AC4 * {(unsigned long)}(X3 + 32768) / 2^15
B7 := (UP - B3) * (50000 >> oss) '* ' B7 := {((unsigned long))}(UP - B3) * (50000 >> oss)
if (B7 < $8000_0000) ' if (B7 < $8000_0000)
P := (B7 << 1) / B4 ' p := (B7 * 2) / B4
else ' else
P := (B7 / B4) << 1 ' p := (B7 / B4) * 2
X1 := (P ~> 8) * (P ~> 8) ' X1 := (p / 2^8) * (p/2^8)
X1 := (X1 * 3038) ~> 16 ' X1 := (X1 * 3038) / 2^16
X2 := (-7357 * P) / 65536 ' X2 := (-7357 * p) / 2^16
P := P + (X1 + X2 + 3791) ~> 4 ' p := p + (X1 + X2 + 3791) / 2^4
PUB WindSpeed | PlsCnt'cog
'Set up the counters
ctra := %01110 << 26 + pin1 'counter A in NEG edge detect mode
frqa := 1 'increment 1 per pulse
'pulse count loop
repeat
phsa := 0 'reset count registers
waitcnt(clkfreq *2 + cnt) 'wait gate time of 2 second
PlsCnt := phsa 'read the puls counts
'convert pulse count to RPM and display
speed := PlsCnt 'pulse average divided by 2 segments times 60 seconds
PUB hex(value, digits)
'' Returns pointer to a digits-wide hexadecimal string
clrstr(@nstr, MAX_LEN)
return hexstr(value, digits)
PRI clrstr(strAddr, size)
' Clears string at strAddr
' -- also resets global character pointer (idx)
bytefill(strAddr, 0, size) ' clear string to zeros
idx~ ' reset index
PRI hexstr(value, digits)
' Converts value to digits-wide hexadecimal string equivalent
' -- characters written to current position of idx
' -- returns pointer to nstr
digits := 1 #> digits <# 8 ' qualify digits
value <<= (8 - digits) << 2 ' prep most significant digit
repeat digits
nstr[idx++] := lookupz((value <-= 4) & $F : "0".."9", "A".."F")
return @nstr
PUB RTCcog
repeat
I2C.readbytes(RTC,0,@timbuf,7)
waitcnt(clkfreq /2 + cnt)
I've attached a screenshot with some garbage in the wind direction box.
Could it have anything to do with initing the screen (writing the text words) at the beginning of the program and never refreshing it?
As I write this, there has now appeared some garbage just after the wind direction data.
Aaron
@AGCB
you use my "VGACOLOR_320x240_CURSOR.spin" - Driver.
Can you post the whole Code?
Maybe i can help you.
Greetings from Nuremberg, Germany
Werner
13,489 characters too long to post. Is there a way around this?
Aaron
Zip it up in the Propeller tool, and attach the zip.
Thanks Aaron
i think i found the Error:
The "decxy" Method in the Mainloop and the "decxy" in the "Windspeed"-Cog
fight against each other.
Make this Changes:
DAT ' Add the new "pos2" var, add "print2", "decxy2" and "prn2" ' Change in "WindSpeed" "decxy" to "decxy2" ' Hope this will help... VAR long pos2 ' Global Screen-Pointer #2 PRI print2(fgc, bgc, char) ''************************************************ ''* Print Character char at current pos2 * ''* with Foreground-Color fgc and * ''* Background-Color bgc * ''************************************************ vgabuff[pos2++] := char vgabuff[pos2++] := bgc * 16 + fgc PRI decxy2(x, y, fg, bg, val) pos2 := getPos(x, y) prn2(fg, bg, val) print2(fg, bg, $20) PRI prn2(fg, bg, val) | dig dig := 48 + (val // 10) val := val/10 if val > 0 prn2(fg, bg, val) print2(fg, bg, dig) PUB WindSpeed | PlsCnt'cog 'Set up the counters ctra := %01110 << 26 + pin1 'counter A in NEG edge detect mode frqa := 1 'increment 1 per pulse 'pulse count loop repeat phsa := 0 'reset count registers waitcnt(clkfreq *2 + cnt) 'wait gate time of 2 second PlsCnt := phsa 'read the puls counts 'convert pulse count to RPM and display speed := PlsCnt 'pulse average divided by 2 segments times 60 seconds ' decxy(11, 3, $08, $00, speed) decxy2(11, 3, $08, $00, speed) ' use it's own "decxy" Method
Werner
Werner, how do I get a 'degree symbol' to print in VGA? When I put one in from the Propeller font is just gives a squiggly line.
Aaron
Would you please give me some basic info on how to use that Cp437_8_new.bmp font. I've tried to figure it out on my own but haven't.
Aaron
the "CP437_8_NEW.BMP" (256 Colors) is the Template for the "CP437_8.BMP" (2 Colors).
In the "CP437_8_NEW.BMP" (256 Colors) i see the unused Characters. (green/darkgreen)
The "CP437_8.BMP" must have only 2 Colors.
The 'degree symbol' is always available in the "CP437_8.BMP" File, as Char $BF,
The green Char:
PRI updateTemp 'this is inside temp from baro sensor decxy(10, 9, $0A, $00, (T * 9 / 5 + 320)/(10)) ' Print farenheit str(13, 9, $0A, $00, @strF) ' Print "°F" DAT strF byte $BF, "F", 0
I hope all is clear...
Werner
Aaron
However, I'd like to do a few changes in the program code but can't seem to get in. When I try it says "can't find file CP437_8.bmp in work folder or library". I tried to add it to library but it won't allow. It is already in the same folder as the main code.(I think)
I've tried multiple things to correct this to no avail. I remember having the same problem when I was 1st working on this but somehow got it to work.
I wanted to see if there were any cogs left to put in a 'onewire' temperature display and also wanted to add a automatic daylight savings time correction.
Please advise me.
Aaron
