Spurius characters occationally
in Propeller 1
The weather program that I've been working on for a while is nearing completion, thanks to a lot of help from this forum!
Sometimes weird characters show up after running it. If left for hours it also sometimes locks up. I don't know how to figure this out. There must be some anomaly somewhere.
How do I check for this?
There are also a few other things that need completing.
It's a long program, but if anyone has time on their hands and could point me to some bad code, that would be appreciated?
OBJ vga: "VGACOLOR_320x240_CURSOR" ' VGA Driver need 2 Cog's i2c : "I2C pasm driver v1.8od" PUB main cognew(windSpeed,@stack) cognew(RTCcog,@Rtcstack) init initScreen ms := 0 repeat dira[16]~~ Winput:=I2C.readByte(MCP,GPIOA) ' wind direction dir:=winput updateDir waitcnt((clkfreq / 1000) * 1 + cnt) ' wait 1 ms 'get_measurements '' reads temperature and pressure into UT and UP I2C.writeByte(BMP,CONTROL,TEMP) ' start a temperature measurement waitcnt(cnt + clkfreq / 10000 * 45) ' wait 4.5ms UT := I2C.readWordB(BMP,ADC) ' read temperature I2C.writeByte(BMP,CONTROL,PRESSURE) ' start a pressure measurement - 0 oversampling waitcnt(cnt + clkfreq / 10000 * 45) ' wait 4.5ms UP := I2C.readWordB(BMP,ADC) ' read pressure convert_measurements PSI:=(p-1280)/(32) updateSpeed waitcnt(clkfreq/2+cnt) ms++ str(15,27, $0F, $00,string("reset at 0")) decxy(27, 27, $08, $00, (120 - ms)) if ms=>120 'works out to be every 71 seconds ms := 0 'clear and restart counter gust := 0 'clear gusts updatetime if (ms==40) OR (ms==80) OR (ms==2) updateTemp updateBarom updateHDC outa[16]~~ waitcnt(clkfreq + cnt) 'adds a second to the ms countdown outa[16]~ PRI updateSpeed ' 'decxy(11, 3, $08, $00, speed) updategusts updateMax PRI updateGusts if speed > gust gust:= speed if ms==120 gust:=0 decxy(29,3,$0B,$00,gust) PRI updateMax if speed > maxWind maxWind := speed decxy(11,5,$0B,$00,maxWind) hex(timbuf[2],2) str(19, 5, $0B, $00,@nstr) str(21, 5, $0B, $00, string(":")) hex(timbuf[1],2) str(22, 5, $0B, $00,@nstr) PRI updateTime 'this is time in lower right corner hex(timbuf[2],2) 'convert hours to string stored at nstr str(31, 25, $0B, $00,@nstr) str(33, 25, $0B, $00, string(":")) hex(timbuf[1],2) str(34, 25, $0B, $00,@nstr) str(36, 25, $0B, $00, string(":")) hex(timbuf[0],2) str(37, 25, $0B, $00,@nstr) PRI updateTemp 'this is inside temp from baro sensor decxy(10, 9, $0A, $00, (T * 9 / 5 + 320)/(10)) ' Print farenheit str(13,9,$0A,$00,string("F")) PRI updateBarom decxy(23, 9, $0B, $00,PSI) str(28,9,$0E,$00,string("2 decimals")) PRI updateHDC | local_long local_long := HDC << 1 | 1 I2C.command(HDC,$00) 'start a temp, hum measurement waitcnt(clkfreq/10+cnt) I2C.arbitrary(@local_long,1,@local_long,4) waitcnt(clkfreq/10+cnt) temp_C := local_long.byte[0] << 8 | local_long.byte[1] temp_C := temp_C * 165 / 65536 - 40 Far := temp_C * 9/5+32 decxy(10,11,$0A,$00,Far) 'this is outside temp str(13,11,$0A,$00,string("F")) RH := local_long.byte[2] << 8 | local_long.byte[3] RH := RH * 100 / 65536 str(10,14,$0F,$00,string("RH")) decxy(13,14,$0A,$00,RH) str(15,14,$0A,$00,string("%")) DP := Far - ((100-RH)/5) str(17,14,$0F,$00,string("DP")) decxy(20,14,$0A,$00,DP) str(23,14,$0A,$00,string("F")) PRI updateDir binxy(8, 16, $0E, $00, Winput, 8) ' Print binary Winput cyan on black case Winput %0000_0110: '128 updateNeedle(@wind_N) str(12, 7, $0D, $00,string("N ")) %0000_0100: '129 updateNeedle(@wind_NNE) str(12, 7, $0D, $00,string( "N NE")) %0000_1100: '1 updateNeedle(@wind_NE) str(12, 7, $0D, $00,string("NE ")) PRI updateNeedle(ptr) | x, y repeat y from 19 to 25 repeat x from 2 to 8 printxy(x, y, $0D, $00, byte[ptr++]) ' Print Needle white on black PRI init | i, j, k, p1, offs ''************************************************ ''* Start VGA Cog's, Clear Screen and * ''* set Cursor's * ''************************************************ I2C.start(scl,sda,bitrate) offs := 62 ' 62 Bytes BMP-Header not used, 128x128 2 Color Bitmap repeat i from 15 to 0 repeat j from 7 to 0 p1 := (i * 16) + (j * 256) repeat k from 0 to 15 fontbuff[p1+k] := reverse(font[offs++]) wordfill(@vgabuff, $0F20, 1200) ' Clear Screen with $20 (Space) FG-Color $F (white), BG-Color $0 (black) vga.start(video, @vgabuff, @fontbuff, @cursor, @sync) ' Start Video Driver waitcnt(clkfreq * 1 + cnt) ' wait 1 second for cogs to start I2C.writeWordB(HDC,Config_reg,Config_params) 'configure HDC waitcnt(clkfreq/10+cnt) str(0, 16, $0F, $00, @strWinput) ' Print "Winput" white on black PRI reverse(val) : new | i ''************************************************ ''* Reverse a Byte * ''* eg. %01000000 = $40 to %00000010 = $02 * ''************************************************ i := 1 val <<= 32 - 8 repeat 8 if ((val <-= 1) & 1) == 1 new += i i *= 2 PRI getPos(x, y) return (x + y * 40) * 2 PRI print(fgc, bgc, char) ''************************************************ ''* Print Character char at current pos * ''* with Foreground-Color fgc and * ''* Background-Color bgc * ''************************************************ vgabuff[pos++] := char vgabuff[pos++] := bgc * 16 + fgc PRI printxy(x, y, fgc, bgc, char) ''************************************************ ''* Print Character char at current pos * ''* with Foreground-Color fgc and * ''* Background-Color bgc * ''************************************************ pos := getPos(x, y) print(fgc, bgc, char) PRI str(x, y, fgc, bgc, string_ptr) ''************************************************ ''* Print String at x, y * ''* with Foreground-Color fgc and * ''* Background-Color bgc * ''************************************************ pos := (x + y * 40) * 2 repeat strsize(string_ptr) print(fgc, bgc, byte[string_ptr++]) PRI drawBox(x, y, w, h, fgc, bgc) | t1, m, b, i ''************************************************ ''* Draw Box at x, y with w = width, h = height * ''* Foreground.Color fgc * ''* Background-Color bgc * ''************************************************ t1 := (y * 40 + x) * 2 m := t1 + 80 b := m + ((h-2) * 80) pos := t1 print(fgc, bgc, $80) fill(fgc, bgc, $81, w-2) print(fgc, bgc, $82) repeat i from 0 to h-3 pos := m + i * 80 print(fgc, bgc, $86) fill(fgc, bgc, $20, w-2) print(fgc, bgc, $86) pos := b print(fgc, bgc, $83) fill(fgc, bgc, $81, w-2) print(fgc, bgc, $84) PRI fill(fgc, bgc, char, len) | x ''************************************************ ''* Fill len of Char's with char * ''* Foreground.Color fgc * ''* Background-Color bgc * ''* at current pos * ''************************************************ if len <> 0 repeat x from 1 to len print(fgc, bgc, char) PRI decxy(x, y, fg, bg, val) pos := getPos(x, y) prn(fg, bg, val) print(fg, bg, $20) PRI prn(fg, bg, val) | dig dig := 48 + (val // 10) val := val/10 if val > 0 prn(fg, bg, val) print(fg, bg, dig) PRI binxy(x, y, fgc, bgc, value, digits) ''************************************************ ''* Print binary value at x, y * ''* with Foreground-Color fgc and * ''* Background-Color bgc * ''************************************************ pos := (x + y * 40) * 2 value <<= 32 - digits repeat digits print(fgc, bgc, (value <-= 1) & 1 + "0") PUB convert_measurements | X1, X2, X3, B3, B4, B5, B6, B7, oss ' converts uncalibrated UT and UP into calibrated temperature T and pressure P X1 := ((UT - AC6) * AC5) ~> 15 ' X1 := (UT - AC6) * AC5 / 2^15 X2 := ~~MC << 11 / (X1 + ~~MD) ' X2 := MC * 2^11 / (X1 + MD) B5 := X1 + X2 ' B5 := X1 + X2 T := (B5 + 8) ~> 4 ' T := (B5 + 8) / 2^4 oss := 0 B6 := B5 - 4000 ' B6 := B5 - 4000 X1 := (B2 * ((B6 * B6) ~> 12)) ~> 11 ' X1 := (B2 * (B6 * B6 / 2^12)) / 2^11 X2 := (~~AC2 * B6) ~> 11 ' X2 := AC2 * B6 / 2^11 X3 := X1 + X2 ' X3 := X1 + X2 B3 := (AC1 * 4 + X3) ~> 2 '* ' B3 := ((AC1 * 4 + X3) << oss + 2) / 4 X1 := (~~AC3 * B6) ~> 13 ' X1 := AC3 * B6 / 2^13 X2 := (B1 * ((B6 * B6) ~> 12)) ~> 16 ' X2 := (B1 * (B6 * B6 / 2^12)) / 2^16 X3 := ((X1 + X2) + 2) ~> 2 ' X3 := ((X1 + X2) + 2) / 2^2 B4 := (AC4 * (X3 + 32768)) ~> 15 ' B4 := AC4 * {(unsigned long)}(X3 + 32768) / 2^15 B7 := (UP - B3) * (50000 >> oss) '* ' B7 := {((unsigned long))}(UP - B3) * (50000 >> oss) if (B7 < $8000_0000) ' if (B7 < $8000_0000) P := (B7 << 1) / B4 ' p := (B7 * 2) / B4 else ' else P := (B7 / B4) << 1 ' p := (B7 / B4) * 2 X1 := (P ~> 8) * (P ~> 8) ' X1 := (p / 2^8) * (p/2^8) X1 := (X1 * 3038) ~> 16 ' X1 := (X1 * 3038) / 2^16 X2 := (-7357 * P) / 65536 ' X2 := (-7357 * p) / 2^16 P := P + (X1 + X2 + 3791) ~> 4 ' p := p + (X1 + X2 + 3791) / 2^4 PUB WindSpeed | PlsCnt'cog 'Set up the counters ctra := %01110 << 26 + pin1 'counter A in NEG edge detect mode frqa := 1 'increment 1 per pulse 'pulse count loop repeat phsa := 0 'reset count registers waitcnt(clkfreq *2 + cnt) 'wait gate time of 2 second PlsCnt := phsa 'read the puls counts 'convert pulse count to RPM and display speed := PlsCnt 'pulse average divided by 2 segments times 60 seconds decxy(11, 3, $08, $00, speed) PUB hex(value, digits) '' Returns pointer to a digits-wide hexadecimal string clrstr(@nstr, MAX_LEN) return hexstr(value, digits) PRI clrstr(strAddr, size) ' Clears string at strAddr ' -- also resets global character pointer (idx) bytefill(strAddr, 0, size) ' clear string to zeros idx~ ' reset index PRI hexstr(value, digits) ' Converts value to digits-wide hexadecimal string equivalent ' -- characters written to current position of idx ' -- returns pointer to nstr digits := 1 #> digits <# 8 ' qualify digits value <<= (8 - digits) << 2 ' prep most significant digit repeat digits nstr[idx++] := lookupz((value <-= 4) & $F : "0".."9", "A".."F") return @nstr PUB RTCcog repeat I2C.readbytes(RTC,0,@timbuf,7) waitcnt(clkfreq /2 + cnt)
I've attached a screenshot with some garbage in the wind direction box.
Could it have anything to do with initing the screen (writing the text words) at the beginning of the program and never refreshing it?
As I write this, there has now appeared some garbage just after the wind direction data.
Aaron
@AGCB
you use my "VGACOLOR_320x240_CURSOR.spin" - Driver.
Can you post the whole Code?
Maybe i can help you.
Greetings from Nuremberg, Germany
Werner
13,489 characters too long to post. Is there a way around this?
Aaron
Zip it up in the Propeller tool, and attach the zip.
Thanks Aaron
i think i found the Error:
The "decxy" Method in the Mainloop and the "decxy" in the "Windspeed"-Cog
fight against each other.
Make this Changes:
Werner
Werner, how do I get a 'degree symbol' to print in VGA? When I put one in from the Propeller font is just gives a squiggly line.
Aaron
Would you please give me some basic info on how to use that Cp437_8_new.bmp font. I've tried to figure it out on my own but haven't.
Aaron
the "CP437_8_NEW.BMP" (256 Colors) is the Template for the "CP437_8.BMP" (2 Colors).
In the "CP437_8_NEW.BMP" (256 Colors) i see the unused Characters. (green/darkgreen)
The "CP437_8.BMP" must have only 2 Colors.
The 'degree symbol' is always available in the "CP437_8.BMP" File, as Char $BF,
The green Char:
I hope all is clear...
Werner
Aaron
However, I'd like to do a few changes in the program code but can't seem to get in. When I try it says "can't find file CP437_8.bmp in work folder or library". I tried to add it to library but it won't allow. It is already in the same folder as the main code.(I think)
I've tried multiple things to correct this to no avail. I remember having the same problem when I was 1st working on this but somehow got it to work.
I wanted to see if there were any cogs left to put in a 'onewire' temperature display and also wanted to add a automatic daylight savings time correction.
Please advise me.
Aaron
