Escaping corners activity limit to 3 min roaming time
in BASIC Stamp
Hi all,
I'm just going through the activities in the book. I'm new to programming and robotics.
I completed the Escaping corners activity in Ch 5. page 161.
The bot goes on in an infinite loop and I would like to limit the time it runs to stop at about 3 minutes. I don't care if it is exact.
Any pointers would be appreciated.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Program Running"
pulseCount VAR Byte
counter VAR Nib
old7 VAR Bit
old5 VAR Bit
FREQOUT 4, 2000, 3000
counter = 1
old7 = 0
old5 = 1
DO
IF (IN7 <> IN5) THEN
IF (old7 <> IN7) AND (old5 <> IN5) THEN
counter = counter + 1
old7 = IN7
old5 = IN5
IF (counter > 4) THEN
counter = 1
GOSUB back_up
GOSUB turn_left
GOSUB turn_left
ENDIF
ELSE
counter = 1
ENDIF
ENDIF
IF (IN5 = 0) AND (IN7 = 0) THEN
GOSUB back_up
GOSUB turn_left
GOSUB turn_left
ELSEIF (IN5 = 0) THEN
GOSUB back_up
GOSUB turn_right
ELSEIF (IN7 = 0) THEN
GOSUB back_up
GOSUB turn_left
ELSE
GOSUB forward_pulse
ENDIF
LOOP
forward_pulse:
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
RETURN
turn_left:
FOR pulseCount = 0 TO 20
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
RETURN
turn_right:
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
back_up:
FOR pulseCount = 0 TO 40
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
Did you know that you can add a condition to a DO...LOOP?
Refer to the DO...LOOP command in The BASIC Stamp Manual (bottom of Page 176).
https://www.parallax.com/sites/default/files/downloads/27218-Web-BASICStampManual-v2.2.pdf
Notice the END command after LOOP in the Demo program on page 177.
The END command is explained on page 187.
As for timing, do you see that each move routine has a PAUSE 20.
The PAUSE command is on page 311.
How many of these pauses would be in a minute?
If you have a time variable increment (add 1 to it) after each PAUSE 20 then you will have a rough timer.
Once your time variable hits the magic number your program will stop.
This is optional but I like to use CONstants at the top of my program so I can easily make changes.
The CON directive is explained on pages 94 to 96.
The BOE-Bot uses a BASIC Stamp 2 (BS2) so ignore anything regarding the BS1.
