Why Prop C program doses not run for ever?
in Propeller 1
I am trying out Prop c programing.
T wrote the attached program with "While(1)" and is suppose to run for ever,
but runs only for 1min and 15 sec, the program shuts down. The program is running in a Propeller Activity board WX.
This is repeatable.
I would like a guru to explain this issue.
Thank you.
P.S : the zip file is attached
This is repeatable.
Thank you.
Cannot help till we see what you are doing.
I attached the file here.
Siri
Thanks. Your solution worked.
Siri
