Prop2 FPGA files!!! - Updated 2 June 2018 - Final Version 32i - Page 142 — Parallax Forums
1139140142144145160
    edited 2018-05-20 04:04
    TAQOZ is a very easy way to check out hardware, both the P2 itself and whatever you have connected to it. TAQOZ has some SD utilities in ROM but they need further testing however if you paste in this file through your terminal with a line delay of 15ms (char delay = 0) it will give you the full FAT32 system. If you have Flash as well you can even BACKUP that into Flash. However with these tools you should be able to discover what is happening. I may add some diagnostic messages to that source file to make it easier to figure out what's going on. But try it for now.
    TAQOZ#   Parallax P2  .:.:--TAQOZ--:.:.  V1.0         180519-1500
    TAQOZ#   ok
    TAQOZ# lsio
    P:00000000001111111111222222222233333333334444444444555555555566
    P:01234567890123456789012345678901234567890123456789012345678901
    =:d~~~ddddd~dd~~~~~~~~~~~~~~~~~~~~~~~~hhhdh~d~ddd~~~hdhhdd~~h~hh ok
    TAQOZ# MOUNT
    Mounted WIDGET      8C0D_A960-6338_6430 [SDSL08G]          FAT32    7,944MB (32kB/cluster)  ok
    TAQOZ# ls
    /WIDGET
    DUMPV4  .FTH   EASYFILE.FTH   EASYNET .FTH   EXTEND  .FTH   LIFE    .FTH
    LOVE    .WAV   POPCORN .WAV   SEEDAWN .FTH   SPLAT-V4.FTH   TACHYO~1.SPI
    WARPEACE.TXT   ROM_136X.OBJ     ok
    TAQOZ# FOPEN ROM_136X.OBJ...opened at 0000_CE00   ok
    TAQOZ# 0 $40 FS DUMPL
    00000- FECF_C000 FAC4_1361 F8D0_0E09 FD60_0E00     '....a.........`.'
    00010- F104_0E01 FB6C_11FB FD9F_FFFC 3000_0000     '......l........0'
    00020- 0000_4000 0000_0000 0000_0000 0000_0000     '.@..............'
    00030- 0000_0000 0000_0000 0000_0000 0000_0000     '................' ok
  • Cluso
    What modifications did you do to the BeMicro-A9 to work with SD?
    Demo v002
    Init failed ***
    MBR  failed ***
    Dir  failed ***
    File failed ***
  • We are testing SD on the CVA9 as an external device but perhaps those who are not testing would like to use the internal card which requires boot pins mapped internal, which then means no Flash.
    edited 2018-05-20 04:33
    I am seeing something amiss with SD booting. It's not tied down yet.
    I boot with and SD card that does not have valid files "_BOOT_P2.BIX" or "_BOOT_P2.BIY".
    The boot seems to go fine, and finding that no file is present, it jumps to Chip's serial boot. So far so good.
    Now I can invoke the monitor with "> "<cr> and even run a rile on the SD.
    BUT, pnut (tried a couple, but the latest too), cannot find the P2 at all. Then I can open PST and do "> "<cr> and up comes the monitor fine.
    FYI attached are 3 P2 files that flash leds. the filename explains which led flashes (1 sec on, 1 off). Red is on P5, blue on P7 and green on P9.
    FWIW Be careful when renaming your files. Uppercase to lower case doesn't work with Windows. You need to delete the file properly and then copy a fresh one.
    and no sd as there is a pullup on P59 too, so goes straight to serial :(
    Oh!
    I will have to put a breakout board together tomorrow.
    Shame though, I also have a DE2-115 with a SD socket but no image is available for that. :(
  • cgraceycgracey Posts: 14,277
    Cluso99 wrote: »
    pnut
    I had a typo and pnut compiled it
    if_n call #_HubTxString
    The assembler saw 'if_n' as a label, since it wasn't a valid condition, but met label-name criteria.
    Cluso99 wrote: »
    pnut
    Thanks Chip. That explains it.
    Any thoughts about why pnut cannot find the P2 while the P2 is running serial awaiting the autobaud sequence?
  • I have in my collection of stuff a "Parallax Memory Card #40004" with SD and flash on board.
    The board will need modification though as the card switch pills MOSI low.
    505 x 535 - 57K
    Cluso99 wrote: »
    Cluso99 wrote: »
    pnut
    Do you mean at 4800 baud? I'm looking into that right now.
  • ozpropdev wrote: »
    Flick R2 off with a hot iron (and maybe a blob of solder) as it is never needed and will interfere with boot detection.
    garryj wrote: »
    Cluso99 wrote: »
    Garry (and all)
    Garry, compile and download this program using pnut. If your SD had been working and there was valid boot code, this program would not run. So you would need to insert the SD card after the "Demo.." message while the program stalls waiting for operator input. Once you hit enter, the program will try the SD card and report a couple of status points reached. Let me know where it fails please, and I will break it down some more.
    Renamed the file to run to "_BOOT_P2.BIZ".
    At the "Demo..." prompt I insert the SDCard then Enter and get:
    Init passed
    MBR  passed
    DIR  passed
    No further messages appear, so it looks like something may be going awry in the monitor #readFILE routine, as I assume that "File failed" should be output if the call had returned with an error status?
    I think it more likely that the file being loaded and run is broken. I posted some demo files to flash pins a few posts back.
    You could also try this patch in the ROM to fix that missing wz. It applies to SD1 cards, and causes an error to be reported rather than continuing.
    *fc620L
     addr  -0--1--2--3  -4--5--6--7  -8--9--A--B  -C--D--E--F
    FC620- 05 8C 07 F2  2C 04 90 5D  00 86 07 F6  77 80 07 F6   '....,..]....w...'
    *fc620- 05 8c 0f f2
    *fc620L
    FC620- 05 8C 0F F2  2C 04 90 5D  00 86 07 F6  77 80 07 F6   '....,..]....w...'
    *R<filename><cr>
  • Flick R2 off with a hot iron (and maybe a blob of solder) as it is never needed and will interfere with boot detection.
    Roger wilco.
  • jmgjmg Posts: 15,190
    From my reading, those were separate issues ?
    Cluso99 wrote: »
    This is because PNut only waits 100ms for a response. The SD boot failure may take several times that.
    I made the SPI check go really fast so that we could be timely with the serial check. SD boot failure doesn't happen in 5ms, like SPI.
    I would have to lengthen the timeout in PNut to accommodate SD failure. This means it would take a lot longer to find a Prop2 on all the serial ports it may need to scan.
    Cluso99 wrote: »
    Can you lengthen the timeout, at least for now. It's probably more difficult to set a com port to use and allow more time.
    Currently there is no way to load if an SD card is present.
    Oops!
    Just overflowed ROM by ~20 bytes when adding write to SD. :(
    No file system in place, just raw sector address.
    edited 2018-05-20 05:45
    In looking at the 4800 baud problem (it doesn't auto-baud that low), I see the problem.
    Within autobaud_isr, the max measurement allowed is $58E4 ('limit'). This gets multiplied by $1_0000/7 = $2492 ('baud0'). The product is $0CB2C208. The top 16 bits become the bit period in system clocks: $0CB2 = 3250. At 20MHz, that's a maximum bit period of 3250 / 20M = 162.5us = 6153 baud. That's why 4800 baud fails, it's too slow. Really, that RC oscillator can run up to 30MHz in the fast corner. That would increase the minimum baud to 6153 * (30M/20M) = 9230 baud. So, 9600 baud needs to be considered as the lower baud limit for the auto-baud detector. At the other extreme, it can go up to 2M baud in the slow corner.
    So, the actual auto-baud range for the booter must be declared as 9,600 to 2,000,000 baud. I will change the Google Doc now.
    Cluso99 wrote: »
    Cluso99 wrote: »
    Okay. How long of a timeout do we need? 1 second?
    edited 2018-05-20 05:57
    Cluso99 wrote: »
    Cluso99 wrote: »
    I allow around half a second for SD cards so 1 second should be fine.
    I also saw that 9600 baud limit the other day but I didn't consider it a problem. Now if you can't go above 4800 baud, now that is a problem :)
    edited 2018-05-20 07:05
    ozpropdev wrote: »
    Oh!
    I updated the FPGA-images-with-new-ROM file at the top of this thread and there's now a DE2-115 image. The SPI/SD pins (P61..P58) are mapped directly to the general-purpose I/O's, not the built-in SD card socket.
    Within autobaud_isr, the max measurement allowed is $58E4 ('limit'). This gets multiplied by $1_0000/7 = $2492 ('baud0'). The product is $0CB2C208. The top 16 bits become the bit period in system clocks: ...
    Is that a limit in the Smart Hardware (eg 16b Divider ?), or just a limit in the maths of a fitting the scale into a 32b result ?
    edited 2018-05-20 07:15
    jmg wrote: »
    It's a limit of the math operations. Do you think we should make it work with lower bauds?
  • cgracey wrote: »
    No, unless you want to accommodate Heater and his Flexowriter. Will the serial loader support paper tape in EBCDIC format?
  • cgracey wrote: »
    Thanks Chip for the DE2-115 image.
    ozpropdev wrote: »
    I hope it works. It should.
    edited 2018-05-20 08:47
    ozpropdev wrote: »
    Just checked it on a DE2 - all good!
    TAQOZ# lsio
    =:~~~~~~~~~~~~~~~~~~~~~~~~~~~~dhhhdddddhhhhhhddhhhhddddddddd~~~~ ok
    80MHZ
    $FF HUBSET
    DE2 LED chaser in TAQOZ
    BEGIN 50 32 DO I HIGH 20 ms I LOW LOOP KEY UNTIL
    Slow it down by pressing key3
    BEGIN 50 32 DO I HIGH 31 PIN@ IF 20 ms ELSE 100 ms THEN I LOW LOOP KEY UNTIL
    jmg wrote: »
    Does that mean I cannot use P2 with my 300 baud acoustic coupler modem :(
    https://en.m.wikipedia.org/wiki/Modem#/media/File:Analogue_modem_-_acoustic_coupler.jpg
    Cluso99 wrote: »
    Cluso99 wrote: »
    1second would be fine.
    Might it be easy to do a quick run thru the ports and if not found then repeat with a 1s timeout?
    Peter Jakacki,
    My ears are burning.
    It's OK. Nice that you should think of me but sadly I don't actually have a Flexowriter.
    We can make paper tape fly you know :)
