Spin code for Parallax WX ESP8266 WiFi Module? — Parallax Forums
I'm looking at Parallax WX ESP8266 WiFi Module code examples and seeing only PBASIC and C. Is there really no Spin support for this device?
  • VonSzarvasVonSzarvas Posts: 3,629
    edited 2018-05-11 18:44
    Don't know off-hand about other solutions, but I've been using FullDuplexSerial from Spin.
    For example, this snippet joins a network:
    OBJ
    wificom : "FullDuplexSerial"
    wificom.start(WX_DO,WX_DI,0,115200) ' rxpin, txpin, mode, baudrate
    wificom.rxflush   ' Clear RX buffer
    wificom.str(string($FE,"JOIN:"))
    wificom.str(@ssid)
    wificom.str(string(","))
    wificom.str(@pass)
    wificom.str(string(13,10))
  • mparkmpark Posts: 1,336
    Well, dang, is it just that simple? Thanks!
  • Yeah!
    And just to check... you've found the API document ?
    All the serial commands are detailed there.
    From memory, you might want to set either DO or DI low for a few milliseconds, to toggle the ESP module between serial command mode and transparent mode. The API describes that too.
    https://www.parallax.com/downloads/parallax-wx-wi-fi-module-firmware-guide
    Yup, thanks. My order is supposed to arrive tomorrow. Wish me luck!
  • VonSzarvas wrote: »
    Yeah!
    I've heard that there is a new way to add Wi-Fi connectivity, is this true?
    Is it listed in this guide?
  • Can't say if it's true without knowing what you've heard.
    Could you share a link and/or explain "what you've heard" ?
