Propeller Proto Board 32212: will 12V hurt it?
in Propeller 1
I've dug out an old proto board and it says "6-9VDC" right next to the DC jack, but how strict is that upper limit anyway? I'd like to run it off 12V. Will that break something?
If they're serious about that 9V thing, what's a good way to drop 12V to within the acceptable range?
A lot depends on how much current you're going to draw through the 5V regulator. The only heatsink is the PCB itself and there will be a 7V drop through the 5V regulator that will have to be dissipated as heat. If you add another regulator in the chain, they'll share the heat dissipation. I'd set the LM317 to output 7V. If you're drawing 1A, that's 5W for the LM317, 2W for the 5V regulator, and 1.7W for the 3.3V regulator. The LM317 could have a "real" heatsink and that would keep everything else cooler. If your current draw is a lot less, this is mostly moot. Remove the input capacitor if it's only rated for 10V and substitute a higher voltage unit. Keep it if it's 16V or better.
You did ask about dropping the 12V to within the spec'd range.
Oh, totally. Doesn't mean I'm not going to look for a shortcut
Anyway, you make a good point about the heat dissipation, so I'll bite the bullet and go find an LM317 somewhere. Thanks again!
You could use 1N400x rectifier diodes.
