P2 Monitor/Debug for possible inclusion in the ROM
Cluso99
This is in case Peter cannot fit TAQOZ into the ROM.
The code runs in hub in hubexec mode and supports Serial I/O on P62&63 as well as various list commands that may be called from a users program.
I have detailed the output in previous thread(s).
https://forums.parallax.com/discussion/comment/1435968/#Comment_1435968
This code requires COG $1E0-$1EF for parameter passing to the hubexec code, and a further 128 bytes somewhere in hub ram for buffer and stack space. Currently this is a fixed location, but is intended to be set as a parameter when the serial code is initialised. The baud is already set by a passed parameter to _SerialInit. This will be a second parameter.
The following calls are supported...
Attached is the code for testing.
Please don't ask for features as I don't have the time for discussion as the ROM closes Friday !!!
_HubTx transmit a serial character _HubTxString transmit a serial string, $0 terminated _HubHex transmit in hex _HubList list cog/lut/hub data _HubRx receive a serial character _HubRxString receive a serial string, <cr> terminated _HubMonitor call the monitor/debug with following command formats [[#]xxxxxxxx] [-] [.yyyyy] [,[$]ccccc] z [m] <cr> [xxxxxx] . [yyyyyy] L <cr> List COG/LUT/HUB from addr1 to addr2 Q <cr> Return to user program ? <cr> Display help WIP [xxxxxx] - [xxxxxxxx] ... <cr> Store to address with data... (will take paste of list output format) To do (time permitting) [xxxxxx] G <cr> Goto address [xxxxxx] . [yyyyyy] , [ccccc] M<cr> Move COG/LUT/HUB from addr1 to addr2 for count #[xxxxxxxx] . [yyyyyy] , [ccccc] M<cr> Fill COG/LUT/HUB with data to addr2 for count
As far as I understood @chips posts the ROM had to be at OnSemi TODAY (22) and the ROM closed last Friday.
I am waiting for him to finish with onsemi to finalise the SD Boot for the ROM.
BTW Is anyone actually testing the current P2 v32b code???
I am behind on the debug documentation. Is this needed for the ROM code?
Agreed.
The only other thought was to boot from serial and on another cog run either flash or sd boot. Whichever completed first would stop the other. But this is more complicated and with only days to go might not be worth the risk.
I am not sure where Peter is at with TAQOZ today. I spoke to him over the w/e. In case he's not ready i have been working on a Monitor/Debug that could go in its place.
The boot needs to have fast paths possible into each of UART, SPI, SD.
Fastest entry currently into serial is to continually send a repeating "> Prop_Chk 0 0 0 0 ", and wait for an echo (P2 out of reset) of CR+LF+“Prop_Ver Au”+CR+LF
In the sample program (the cog section) this code will display a piece of code from cog, lut and hub.
Then the user is prompted to enter a string of text terminated with <cr>. <bs> works too, and the characters are echoed.
Next the user program calls the monitor program. Here are some strings to enter to try it out.
The "*" is a prompt character from the monitor.
Most spaces are optional (except in the download where spaces cause the write of the accumulated hex long to be written).
The download format is the same as that output by the "L" list command. pnut outputs with ascii but doesn't have a delimiter quote
I tried to cut and past a line in PST but PST doesn't like it
Please check it works properly.
Please, no requests for added features!
Thanks, but I specifically didn't want to use smartpins in boot code.
It then has to be cleared down, and I didn't want this to be required.
This way, I don't have to worry about interrupts either.
I know Chip has used the smartpin in the boot code.
There are merits both ways. First generation boot loaders needed to be KISS, and so used SW baud.
That also means you have more control over a chip with possible HW faults.
However, Smart pins do allow higher boot baud rates, and that is important.
Smart pins are also now looking mature, with more testing hours on the clock, especially in serial mode...
OnSemi seem to be claiming a high chance of working silicon, and especially of Logic portions, so that risk appears to be lower...
Just looking now at new data on small MCUs that claim up to SysCLK(24MHz)/4 Baud rates.
Ah, here's your init routine, out of the above source file, that uses a couple of Smartpins for the async serial.
''-------[ Serial Routines (uses SmartPins) ]---------------------------------- <--- serial initialise ---> ''_SerialInit '' On Entry: '' lmm_x = _bitper ' tx & rx bit period + #(bits-1) '' Call Format: '' CALL #_SerialInit ' < call: serial initilise> '' On Return: '' lmm_x = #CR ' (changed) ''-------------------------------------------------------------------------------------------------- _SerialInit wrpin ##_txmode, #_txpin ' set asynchronous tx mode in smart pin tx wxpin lmm_x, #_txpin ' set tx bit period + #(bits-1) dirh #_txpin ' enable smart pin tx wrpin ##_rxmode, #_rxpin ' set asynchronous rx mode in smart pin rx wxpin lmm_x, #_rxpin ' set rx bit period + #(bits-1) dirh #_rxpin ' enable smart pin rx mov lmm_x, #CR ' we have to prime send buffer empty flag, wypin lmm_x, #_txpin ' ... so send <cr> to tx pin RET wcz ' <--- return to calling routine ---> ''--------------------------------------------------------------------------------------------------Originally I used bit banging back in the first P2.
Guess I must say it's been working for years.
Just realised why I haven't been able to get my monitor running properly/reliably when I insert it into the boot code.
Serial interrupts are still running from the booter trying to autobaud causing weird serial responses
Off to read the manual on clearing interrupts and resetting smart pins
By a "spooky" coincidence I was messing with autobaud stuff today.
Here is Bootloader code that can be downloaded and run...
Try "> " to set autobaud in Chip's code, followed by one of...
<esc> to run TAQOZ
<ctl-d> to boot a file named "_BOOT_P2.BIX" or _"BOOT_P2.BIY" from an SD card
<ctl-e> to run my monitor
The file _BOOT_P2.BIX.spin2 needs to be renamed (remove ".spin2" - forum requirement) and copied to an SD card. It flashes a LED on P5.
This hubmap counts active bytes in 256 byte blocks capped at $FF (=256). The .. are all zeros and each line represents 4kB which is skipped if it is all zeros (unused).
TAQOZ# HUBMAP 0000.0000 FF .. .. .. 51 .. .. .. .. .. .. .. .. .. .. 02 0000.8000 FC .. .. 08 D7 E5 F5 FF F7 FF FE FF FE FF 32 .. 0000.C000 EE F1 A6 EF E8 D8 CA CD C1 B9 C8 C9 CF C1 F0 D8 0000.D000 DE D0 CA D8 D9 DF BB BD DF DD E7 DF E1 C2 .. .. 0000.E000 .. .. .. .. .. .. .. .. 5F E0 EE E9 EB E1 F6 F2 0000.F000 D4 EF ED E8 D3 E3 F0 EF F0 F2 62 .. .. .. 34 02 0007.C000 EE F1 A6 EF E8 D8 CA CD C1 B9 C8 C9 CF C1 F0 D8 0007.D000 DE D0 CA D8 D9 DF BB BD DF DD E7 DF E1 E4 DA E8 0007.E000 F5 FF F7 FF FD FF FE FF 69 E0 EE E9 EB E1 F6 F2 0007.F000 D4 EF ED E8 D3 E3 F0 EF F0 F2 62 .. .. .. .. .. 000F.C000 EE F1 A6 EF E8 D8 CA CD C1 B9 C8 C9 CF C1 F0 D8 000F.D000 DE D0 CA D8 D9 DF BB BD DF DD E7 DF E1 E4 DA E8 000F.E000 F5 FF F7 FF FD FF FE FF 69 E0 EE E9 EB E1 F6 F2 000F.F000 D4 EF ED E8 D3 E3 F0 EF F0 F2 62 .. .. .. .. .. ok TAQOZ# WORDS DUP OVER SWAP ROT -ROT DROP 3RD 4TH 2DROP 3DROP NIP 2SWAP 2DUP ?DUP AND ANDN OR XOR ROL ROR >> << SAR 2/ 2* 4/ 4* 8<< 16>> 8>> 9<< 9>> REV |< >| >N >B >9 BITS NOT = <> 0= 0<> 0< < U< > U> <= => WITHIN DUPC@ C@ W@ @ C+! C! C@++ W+! W! +! ! BIT! SET CLR SET? 1+ 1- 2+ 2- 4+ + - UM* * W* / U/ U// // */ UM// C++ C-- W++ W-- ++ -- RND GETRND SQRT ~ ~~ W~ W~~ C~ C~~ L>S >W L>W W>B W>L B>W B>L MINS MAXS MIN MAX ABS -NEGATE ?NEGATE NEGATE ON TRUE -1 FALSE OFF GOTO IF ELSE THEN BEGIN UNTIL AGAIN WHILE REPEAT SWITCH CASE@ CASE= CASE> BREAK CASE ADO DO LOOP +LOOP FOR NEXT ?NEXT I J LEAVE IC@ I+ BOUNDS H L T F R HIGH LOW FLOAT PIN@ WRPIN WXPIN WYPIN RDPIN RQPIN AKPIN WAITPIN WRACK PIN @PIN ns PW PULSE PULSES HILO DUTY NCO HZ KHZ MHZ MUTE BLINK PWM SAW BIT BAUD TXD RXD TXDAT WAITX WAITCNT REBOOT RESET 0EXIT EXIT NOP CALL JUMP >R R> >L L> !SP DEPTH COG@ COG! LUT@ LUT! COGID COGINIT COGSTOP COGATN POLLATN SETEDG POLLEDG KEY KEY! CON NONE COM CONKEY CONEMIT EMIT EMITS CRLF CR CLS DOT SPACE SPACES RAM DUMP: DUMP DUMPW DUMPL DUMPA DUMPAW QD DEBUG lsio COG LUT KB MB M . PRINT .AS .AS" .DECL .DEC4 .DEC2 HOLD #> <# # #S <D> U. .DEC .BIN .B .BYTE .W .WORD .L .LONG .ADDR PRINT$ LEN$ " ." CTYPE ?EXIT DATA? ERASE FILL CMOVE <CMOVE s ms us CNT@ LAP LAP@ .LAP .ms HEX DEC BIN .S WORDS @WORDS GET$ SEARCH $># @DATA HERE @HERE @CODES LOOKIN LOOKUP uemit ukey char delim names TASK REG @WORD SPIN | || , [W] ["] NULL$ $! $= FORGET CREATE$ CREATE VAR pub pri pre module : ; [ ' := == ==! ALIGN DATCON ALLOT org bytes words longs byte word long res [C] GRAB NFA' CPA CFA \ --- ( { } IFNDEF IFDEF IDLE .VER TAQOZ TERM AUTO SPIRD SPIRDL SPIWB SPIWR SPICE SPIWC SPIWW SPIWS SPIPINS SPIRX SPITXE SPITX CLKIN CLKOUT CLOCK WSLED WAIT CLKDIV RCSLOW HUBSET WP WE CLKHZ CLKMHZ BUFFERS ROM IRQVEC PTRA PTRB DIRA DIRB OUTA OUTB INA INB ERROR END 394 okBTW I think all those serial problems were to do with the Interrupt stealing some input characters.
Did you remove, or make the ascii terminal controls optional ?
Am I correct in recalling that TAQOZ interprets the input as it's being entered?
What did you squeeze to save that space?
I removed all the ANSI for starters. I'd like to the SPLAT logic analyzer if I can. Anyone with a terminal can capture port signals and display them easily.
Those commands were built with a group of user callable commands to send characters, hex, string, and read characters, strings, etc. So, it's like a bios for serial. The monitor is just the user friendly (from a command line terminal) section of those calls. I did strip quite a bit of functionality out though.
My understanding is that TAQOZ is more of an alternative language that can be used to test out the hardware. I know Peter is using it to construct real programs but unfortunately I don't expect a lot of users to do this. But it's a great interactive development tool that will hopefully get a lot of people into P2.
Peter has built an amazing piece of code, but it just needs to run at the bottom 64KB.
